주요 콘텐츠로 건너뛰기
Motorola i710 Charger Plug Replacement
필요한 것
  1. Motorola i710 Charger Plug Replacement, Battery Cover: 1 단계, 이미지 1/2 Motorola i710 Charger Plug Replacement, Battery Cover: 1 단계, 이미지 2/2
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
  2. Motorola i710 Charger Plug Replacement, Battery: 2 단계, 이미지 1/1
    • Push the battery towards the top of the phone and lift up.
  3. Motorola i710 Charger Plug Replacement, Back Casing: 3 단계, 이미지 1/3 Motorola i710 Charger Plug Replacement, Back Casing: 3 단계, 이미지 2/3 Motorola i710 Charger Plug Replacement, Back Casing: 3 단계, 이미지 3/3
    • With a T5 screwdriver, unscrew the four T5 sized screws that hold the case back cover onto the rest of the case.
    • Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other.
  4. Motorola i710 Charger Plug Replacement, Charger Plug: 4 단계, 이미지 1/1
    • Once you have taken off the back cover of the phone, the charger tab can be lifted out of position on the back cover.
결론
Caitlin Smith
회원 가입일: 10/22/12
4 평판
안내서 2개 작성하였습니다
Clemson, Team 14-2, Benson Fall 2012 Clemson, Team 14-2, Benson Fall 2012 회원
CLEM-BENSON-F12S14G2
4 회원들
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 397
