주요 콘텐츠로 건너뛰기
Motorola i710 Keypad Sensor Replacement
  1. Motorola i710 Keypad Sensor Replacement, Battery Cover: 1 단계, 이미지 2개 중 1개 Motorola i710 Keypad Sensor Replacement, Battery Cover: 1 단계, 이미지 2개 중 2개
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
  2. Motorola i710 Keypad Sensor Replacement, Battery: 2 단계, 이미지 1개 중 1개
    • Push the battery towards the top of the phone and lift up.
  3. Motorola i710 Keypad Sensor Replacement, Motherboard: 3 단계, 이미지 3개 중 1개 Motorola i710 Keypad Sensor Replacement, Motherboard: 3 단계, 이미지 3개 중 2개 Motorola i710 Keypad Sensor Replacement, Motherboard: 3 단계, 이미지 3개 중 3개
    • Lift the motherboard away from the case of the phone, being careful not to break the wire that goes up into the hinge.
    • Peel the motherboard off of the keypad. The two pieces are glued together and separate without much effort.
    • The motherboard should now be completely disconnected from the phone.
  4. Motorola i710 Keypad Sensor Replacement, Keypad Sensor: 4 단계, 이미지 2개 중 1개 Motorola i710 Keypad Sensor Replacement, Keypad Sensor: 4 단계, 이미지 2개 중 2개
    • Once the motherboard has been removed from the keypad, the keypad sensor can be detached from the phone at the hinge.
    • Gently pry off the cable connecting the keypad sensor. The keypad sensor should now be completely separated from the phone.
결론
작성자
6다른 기여자 명과 함께
Katelyn
회원 가입일: 10/22/12
1 평판
안내서 2개를 작성함
Clemson, Team 14-2, Benson Fall 2012 Clemson, Team 14-2, Benson Fall 2012 회원
CLEM-BENSON-F12S14G2
4 회원들
안내서 17개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 7
전체 시간: 392
