주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
Once the battery and case back cover have been removed, the motherboard can be accessed as shown in this guide.
부품
지정된 부품이 없습니다.
  1. Slide the cover release button towards the bottom of the phone Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
  2. Push the battery towards the top of the phone and lift up.
    • Push the battery towards the top of the phone and lift up.
  3. With a T5 screwdriver, unscrew the four T5 sized screws that hold the case back cover onto the rest of the case. Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other. Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other.
    • With a T5 screwdriver, unscrew the four T5 sized screws that hold the case back cover onto the rest of the case.
    • Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other.
  4. Lift the motherboard away from the case of the phone, being careful not to break the wire that goes up into the hinge. Peel the motherboard off of the keypad. The two pieces are glued together and separate without much effort. The motherboard should now be completely disconnected from the phone.
    • Lift the motherboard away from the case of the phone, being careful not to break the wire that goes up into the hinge.
    • Peel the motherboard off of the keypad. The two pieces are glued together and separate without much effort.
    • The motherboard should now be completely disconnected from the phone.
결론
Carson Meena
회원 가입일: 2012년 10월 22일
16 평판
안내서 5개 작성하였습니다
Clemson, Team 14-2, Benson Fall 2012 Clemson, Team 14-2, Benson Fall 2012 회원
CLEM-BENSON-F12S14G2
4 회원들
안내서 17개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 257
