주요 콘텐츠로 건너뛰기
소개
Replacement of malfunctioning LCD screen.
  1. Open the flip cover of the phone with the LCD screen facing towards you.
    • Open the flip cover of the phone with the LCD screen facing towards you.
  2. Use a Razor Blade to remove the screw covers. Razor Blade is very sharp. Use caution.
    • Use a Razor Blade to remove the screw covers.
    • Razor Blade is very sharp. Use caution.
  3. Unscrew the screws using a Phillips #00 Screwdriver.
    • Unscrew the screws using a Phillips #00 Screwdriver.
  4. Insert a Spudger into the side crack of the flip cover and slowly separate the phone cover from the case.
    • Insert a Spudger into the side crack of the flip cover and slowly separate the phone cover from the case.
  5. Gently separate the flip cover case from the phone with your hands when the crack is wide enough.
    • Gently separate the flip cover case from the phone with your hands when the crack is wide enough.
  6. 안드로이드 수리 키트
    새 스크린 혹은 배터리는 단 하나의 키트로 충분합니다.
    지금 장보기
    안드로이드 수리 키트
    지금 장보기
  7. Partially close the flip cover of the phone in order to take off the outer case.
    • Partially close the flip cover of the phone in order to take off the outer case.
  8. Completely remove the outer casing from the phone.
    • Completely remove the outer casing from the phone.
  9. Place your thumb underneath the protective metal covering to remove it from the phone. Place your thumb underneath the protective metal covering to remove it from the phone.
    • Place your thumb underneath the protective metal covering to remove it from the phone.
  10. Gently detach the black microchip from the phone with a Tweezer.
    • Gently detach the black microchip from the phone with a Tweezer.
  11. Prop out the LCD board from the phone using your fingertips.
    • Prop out the LCD board from the phone using your fingertips.
  12. Remove the LCD board from the phone by grabbing the bottom side of the LCD board. Remove the LCD board from the phone by grabbing the bottom side of the LCD board.
    • Remove the LCD board from the phone by grabbing the bottom side of the LCD board.
  13. Firmly detach the gold strip using a Tweezer.
    • Firmly detach the gold strip using a Tweezer.
  14. Prop out the LCD screen using a Small Flathead Screwdriver.
    • Prop out the LCD screen using a Small Flathead Screwdriver.
  15. Remove the LCD screen from the LCD board. Remove the LCD screen from the LCD board. Remove the LCD screen from the LCD board.
    • Remove the LCD screen from the LCD board.
결론
Andrew Aw
회원 가입일: 2010년 04월 08일
1 평판
안내서 2개 작성하였습니다
Cal Poly, Team 34-56, Forte Spring 2010 Cal Poly, Team 34-56, Forte Spring 2010 회원
CPSU-FORTE-S10S34G56
4 회원들
안내서 10개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,045
