주요 콘텐츠로 건너뛰기
Moultrie I45 GameSpy Casing Replacement
필요한 것
  1. Moultrie I45 GameSpy Casing Replacement, Casing: 1 단계, 이미지 1/1
    • Using a Philips head screwdriver, remove the eight 6mm screws located at the bottom of the device.
  2. Moultrie I45 GameSpy Casing Replacement: 2 단계, 이미지 1/1
    • Remove the butterfly nut from the lid arm.
  3. Moultrie I45 GameSpy Casing Replacement: 3 단계, 이미지 1/1
    • Remove the lid-covering.
  4. Moultrie I45 GameSpy Casing Replacement: 4 단계, 이미지 1/1
    • Using a Phillips head screwdriver, remove the six 4mm screws from the face of the camera.
  5. Moultrie I45 GameSpy Casing Replacement: 5 단계, 이미지 1/1
    • Gently separate the two halves of the case.
    • The two halves are connected by a wire. Pulling too roughly can damage the wires and cause the camera to stop functioning.
결론
Sean Hill
회원 가입일: 01/29/15
485 평판
안내서 4개 작성하였습니다
UW Tacoma, Team 3-7, Rose Winter 2015 UW Tacoma, Team 3-7, Rose Winter 2015 회원
UWT-ROSE-W15S3G7
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 225
