주요 콘텐츠로 건너뛰기
Mountain Bike Brake Lever Replacement
필요한 것
  1. Mountain Bike Brake Lever Replacement, Mountain Bike Brake Lever: 1 단계, 이미지 1/2 Mountain Bike Brake Lever Replacement, Mountain Bike Brake Lever: 1 단계, 이미지 2/2
    • Remove the grip from the handle.
    • Do this by twisting and pulling the grip until it slides off.
  2. Mountain Bike Brake Lever Replacement: 2 단계, 이미지 1/2 Mountain Bike Brake Lever Replacement: 2 단계, 이미지 2/2
    • Using a 5mm allen key, loosen the lever assembly from the handle.
    • Slide the assembly off of the handle.
  3. Mountain Bike Brake Lever Replacement: 3 단계, 이미지 1/1
    • Take your new lever assembly and slide it onto the handle; leave it loose.
  4. Mountain Bike Brake Lever Replacement: 4 단계, 이미지 1/2 Mountain Bike Brake Lever Replacement: 4 단계, 이미지 2/2
    • Pour a light amount of isopropyl alcohol through your grip and slide it back onto the handle.
  5. Mountain Bike Brake Lever Replacement: 5 단계, 이미지 1/1
    • Line up your lever assembly back into place.
    • Tighten the screw with the allen key to secure it.
  6. Mountain Bike Brake Lever Replacement: 6 단계, 이미지 1/3 Mountain Bike Brake Lever Replacement: 6 단계, 이미지 2/3 Mountain Bike Brake Lever Replacement: 6 단계, 이미지 3/3
    • Install the brake cable into the lever housing.
    • Take the brake cable and feed it into the lever pull.
  7. Mountain Bike Brake Lever Replacement: 7 단계, 이미지 1/3 Mountain Bike Brake Lever Replacement: 7 단계, 이미지 2/3 Mountain Bike Brake Lever Replacement: 7 단계, 이미지 3/3
    • Feed the cable into the lever assembly slot and through the barrel adjuster.
    • Use the barrel adjuster to tighten the cable intro place.
결론
Now your lever assembly should be properly hooked up and ready to function! Giving the lever a couple test pulls to make sure it is applying brake pressure is recommended.
다른 한 분이 해당 안내서를 완성하였습니다.
Joe LoCascio
회원 가입일: 01/04/21
180 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 18
30일 전: 103
전체 시간: 3,415
