주요 콘텐츠로 건너뛰기
Mpow 059 Ear Cushion Replacement
필요한 것
  1. Mpow 059 Ear Cushion Replacement, Ear Cushion: 1 단계, 이미지 1/2 Mpow 059 Ear Cushion Replacement, Ear Cushion: 1 단계, 이미지 2/2
    • Place the iFixit opening tool between the soft ear cushion and the hard plastic of the speaker.
    • Pry the soft ear cushion away from the hard plastic using a moderate amount of pressure.
    • There is adhesive holding the ear cushion to the speaker so it may take a little patience to remove.
    • Applying too much pressure can damage ear cushion.
  2. Mpow 059 Ear Cushion Replacement: 2 단계, 이미지 1/1
    • Remove the ear cushion away from the speaker to completely detach it from the headphones.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Danielle Furtado
회원 가입일: 03/25/22
490 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team E-1, Gurgel Spring 2022 UMass Dartmouth, Team E-1, Gurgel Spring 2022 회원
UMASSD-GURGEL-S22SEG1
3 회원들
안내서 4개 작성하였습니다
댓글 8개
thank you. very helpfule.
P Gill - 답글
These instructions do not mention anything about the fact that you need a new adhesive to make the new earpads stay. Now I won't have headphones until I'm able to purchase an adhesive.
Cody Owens - 답글
Is there a recommendation on the replacement ear pads?
Some say glue is needed but does this depend on the replacement pads?
ms13sp - 답글
Works great. I have replaced my earpads 3 times with no glue. I use these MOKOS earpads from amazon. Replacement earpads for Mpow 059
Thanks for the step by step guide. I love these Mpow headphones, mostly for the controls on the right ear.
anotherdee - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 39
30일 전: 150
전체 시간: 6,079
