주요 콘텐츠로 건너뛰기
Mpow MPBH063 Daughterboard Replacement
필요한 것
  1. Mpow MPBH063 Daughterboard Replacement, Daughterboard: 1 단계, 이미지 1개 중 1개
    • Remove four Hex 10 mm screws from the outer speaker cover displaying the speaker's serial number indicated by the red circle.
    • Carefully insert the spudger tool into one of the holes in the cover to pry open the outer cover of the speaker.
  2. Mpow MPBH063 Daughterboard Replacement: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove four JIS J00 12mm screws.
    • Remove the inner speaker cover with the precision tweezers and a spudger if needed.
  3. Mpow MPBH063 Daughterboard Replacement: 3 단계, 이미지 1개 중 1개
    • Unplug the wire connected to the daughterboard.
  4. Mpow MPBH063 Daughterboard Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the silver 10 mm screw from the center of the daughterboard.
  5. Mpow MPBH063 Daughterboard Replacement: 5 단계, 이미지 2개 중 1개 Mpow MPBH063 Daughterboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the daughterboard by carefully lifting the daughterboard out of the speaker with the metal spudger.
    • Use iFixit adhesive remover as directed
    • Before you remove the daughterboard, cut around the edges using the tech knife, and remove the adhesive securing the daughterboard to the speaker.
결론
작성자
4다른 기여자 명과 함께
Jazely Barrera
회원 가입일: 10/09/18
121 평판
안내서 1개를 작성함
Sam Houston State, Team S15-G5, Blackburne Fall 2018 Sam Houston State, Team S15-G5, Blackburne Fall 2018 회원
SHSU-BLACKBURNE-F18S15G5
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 3
전체 시간: 234
