소개
If your coffee maker is experiencing power issues, you may have a faulty power cord. Use this guide to replace the damaged power cord of your Mr. Coffee BVMC-SJX33GT.
Make sure your coffee maker is unplugged and empty of all water before attempting to make any repairs.
필요한 것
Also the front two screws are safety screws: they have a 6 sided star shape with a raised dimple in the center to prevent homebodies from casually opening the machine. (probably from the Sunbeam’s (owns Mr. Coffee) legal dept.) Anyway you will need a security bit to remove the screws and not a phillips screw driver.
Locate the metal clamps.
Using a pair of pliers or your fingers, slide clamps away from tube opening.
Locate the two 11.5mm screws securing the plastic bracket in place.
Unscrew the screws using a #2 Phillip's head screwdriver and remove the bracket.
