주요 콘텐츠로 건너뛰기
Mr. Coffee DRX5 Warming Plate Replacement
필요한 것
  1. Mr. Coffee DRX5 Warming Plate Replacement, Warming Plate: 1 단계, 이미지 1/3 Mr. Coffee DRX5 Warming Plate Replacement, Warming Plate: 1 단계, 이미지 2/3 Mr. Coffee DRX5 Warming Plate Replacement, Warming Plate: 1 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove the two 9mm screws and the three 11mm screws on the bottom of the coffee maker and remove the bottom plastic cover.
  2. Mr. Coffee DRX5 Warming Plate Replacement: 2 단계, 이미지 1/1
    • Slide display out of the way.
  3. Mr. Coffee DRX5 Warming Plate Replacement: 3 단계, 이미지 1/3 Mr. Coffee DRX5 Warming Plate Replacement: 3 단계, 이미지 2/3 Mr. Coffee DRX5 Warming Plate Replacement: 3 단계, 이미지 3/3
    • Using a Phillips #1 screwdriver, remove 12mm screws from heating element bracket and remove bracket.
  4. Mr. Coffee DRX5 Warming Plate Replacement: 4 단계, 이미지 1/1
    • Pull heating element out of the way.
  5. Mr. Coffee DRX5 Warming Plate Replacement: 5 단계, 이미지 1/1
    • Twist warming plate clockwise so that the tab is out of place. Remove warming plate.
결론
Michael Chhim
회원 가입일: 03/21/17
202 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S2-G2, Isaacson Spring 2017 UMass Dartmouth, Team S2-G2, Isaacson Spring 2017 회원
UMASSD-ISAACSON-S17S2G2
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
Interesting that you can take the thing apart, do nothing else but put it back together again, and it’s supposed to be fixed? What about the step of replacing the broken part? I don’t see mention of that.
destravlr - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 568
