주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
부품
지정된 부품이 없습니다.
  1. Use a Phillips #1 screwdriver to remove the two 9mm screws and the three 11mm screws on the bottom of the coffee maker and remove the bottom plastic cover. Use a Phillips #1 screwdriver to remove the two 9mm screws and the three 11mm screws on the bottom of the coffee maker and remove the bottom plastic cover. Use a Phillips #1 screwdriver to remove the two 9mm screws and the three 11mm screws on the bottom of the coffee maker and remove the bottom plastic cover.
    • Use a Phillips #1 screwdriver to remove the two 9mm screws and the three 11mm screws on the bottom of the coffee maker and remove the bottom plastic cover.
  2. Slide display out of the way.
    • Slide display out of the way.
  3. Using a Phillips #1 screwdriver, remove 12mm screws from heating element bracket and remove bracket. Using a Phillips #1 screwdriver, remove 12mm screws from heating element bracket and remove bracket. Using a Phillips #1 screwdriver, remove 12mm screws from heating element bracket and remove bracket.
    • Using a Phillips #1 screwdriver, remove 12mm screws from heating element bracket and remove bracket.
  4. Pull heating element out of the way.
    • Pull heating element out of the way.
  5. Twist warming plate clockwise so that the tab is out of place. Remove warming plate.
    • Twist warming plate clockwise so that the tab is out of place. Remove warming plate.
결론
Michael Chhim
회원 가입일: 2017년 03월 21일
202 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S2-G2, Isaacson Spring 2017 UMass Dartmouth, Team S2-G2, Isaacson Spring 2017 회원
UMASSD-ISAACSON-S17S2G2
3 회원들
안내서 5개 작성하였습니다
Interesting that you can take the thing apart, do nothing else but put it back together again, and it’s supposed to be fixed? What about the step of replacing the broken part? I don’t see mention of that.
destravlr - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 344
