주요 콘텐츠로 건너뛰기
Mr. Coffee DW13 Base Removal
필요한 것
  1. Mr. Coffee DW13 Base Removal, Base: 1 단계, 이미지 1/2 Mr. Coffee DW13 Base Removal, Base: 1 단계, 이미지 2/2
    • Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean.
    • Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
  2. Mr. Coffee DW13 Base Removal: 2 단계, 이미지 1/2 Mr. Coffee DW13 Base Removal: 2 단계, 이미지 2/2
    • Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
  3. Mr. Coffee DW13 Base Removal: 3 단계, 이미지 1/1
    • Gently lift the base cover to expose the inside of the coffee machine.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tess Bradley
회원 가입일: 01/26/14
373 평판
안내서 3개 작성하였습니다
Cal Poly, Team 10-31, Maness Winter 2014 Cal Poly, Team 10-31, Maness Winter 2014 회원
CPSU-MANESS-W14S10G31
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 39
전체 시간: 3,118
