소개
To complete this repair you will need pilers, a Philips head screwdriver, and a flathead screw driver. During this repair you will remove the base of the coffee machine, loosen the support bar, before finally removing the heating plate and prying out the O-ring.
부품
지정된 부품이 없습니다.
Remove the two 13mm screws securing the silver support bracket using a #2 Phillips head screwdriver.
다른 3명이 해당 안내서를 완성하였습니다.
