주요 콘텐츠로 건너뛰기
Mr. Coffee DW13 Power Cord Replacement
필요한 것
  1. Mr. Coffee DW13 Power Cord Replacement, Base: 1 단계, 이미지 1/2 Mr. Coffee DW13 Power Cord Replacement, Base: 1 단계, 이미지 2/2
    • Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean.
    • Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
  2. Mr. Coffee DW13 Power Cord Replacement: 2 단계, 이미지 1/2 Mr. Coffee DW13 Power Cord Replacement: 2 단계, 이미지 2/2
    • Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
  3. Mr. Coffee DW13 Power Cord Replacement: 3 단계, 이미지 1/1
    • Gently lift the base cover to expose the inside of the coffee machine.
  4. Mr. Coffee DW13 Power Cord Replacement, Power Cord: 4 단계, 이미지 1/2 Mr. Coffee DW13 Power Cord Replacement, Power Cord: 4 단계, 이미지 2/2
    • Locate the white tab that covers and holds the power cord in place. It has two screws on either side of it.
    • Use a #2 Philips Head screwdriver to unscrew the two 13mm screws holding the tab in place.
  5. Mr. Coffee DW13 Power Cord Replacement: 5 단계, 이미지 1/2 Mr. Coffee DW13 Power Cord Replacement: 5 단계, 이미지 2/2
    • Gently lift up on the white tab, removing it from the coffee machine.
  6. Mr. Coffee DW13 Power Cord Replacement: 6 단계, 이미지 1/2 Mr. Coffee DW13 Power Cord Replacement: 6 단계, 이미지 2/2
    • Locate the 2 electrical connectors running from the black plastic-coated power cord to the interior of the power switch.
    • One cord is copper colored and ends at the power switch in a silver metal square.
    • The other cord is white and ends at the power switch in a black plastic square.
  7. Mr. Coffee DW13 Power Cord Replacement: 7 단계, 이미지 1/2 Mr. Coffee DW13 Power Cord Replacement: 7 단계, 이미지 2/2
    • Grasp the copper cord close to the power switch. Lightly pull the silver end tab from the end to detach it.
  8. Mr. Coffee DW13 Power Cord Replacement: 8 단계, 이미지 1/2 Mr. Coffee DW13 Power Cord Replacement: 8 단계, 이미지 2/2
    • Lightly pull the white cord away from the power switch by grasping the black plastic-coated head.
    • There are two white cords attached to each other. Pull them apart by grasping the different black heads and separating them.
  9. Mr. Coffee DW13 Power Cord Replacement: 9 단계, 이미지 1/3 Mr. Coffee DW13 Power Cord Replacement: 9 단계, 이미지 2/3 Mr. Coffee DW13 Power Cord Replacement: 9 단계, 이미지 3/3
    • Pull the power cord through the hole at the back of the base of the machine, followed by the two colored cords.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Tess Bradley
회원 가입일: 01/26/14
373 평판
안내서 3개 작성하였습니다
Cal Poly, Team 10-31, Maness Winter 2014 Cal Poly, Team 10-31, Maness Winter 2014 회원
CPSU-MANESS-W14S10G31
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 23
전체 시간: 3,172
