주요 콘텐츠로 건너뛰기
Mr. Coffee DW13 Tubing Replacement
필요한 것
  1. Mr. Coffee DW13 Tubing Replacement, Base: 1 단계, 이미지 1/2 Mr. Coffee DW13 Tubing Replacement, Base: 1 단계, 이미지 2/2
    • Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean.
    • Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
  2. Mr. Coffee DW13 Tubing Replacement: 2 단계, 이미지 1/2 Mr. Coffee DW13 Tubing Replacement: 2 단계, 이미지 2/2
    • Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
  3. Mr. Coffee DW13 Tubing Replacement: 3 단계, 이미지 1/1
    • Gently lift the base cover to expose the inside of the coffee machine.
  4. Mr. Coffee DW13 Tubing Replacement, Tubing: 4 단계, 이미지 1/2 Mr. Coffee DW13 Tubing Replacement, Tubing: 4 단계, 이미지 2/2
    • Identify and remove the two 13mm screws securing the silver support bracket using a phillips head screw driver.
  5. Mr. Coffee DW13 Tubing Replacement: 5 단계, 이미지 1/1
    • Gently lift the silver support bracket freeing the heating plate from the heating coil.
  6. Mr. Coffee DW13 Tubing Replacement: 6 단계, 이미지 1/2 Mr. Coffee DW13 Tubing Replacement: 6 단계, 이미지 2/2
    • Use pliers to pinch and loosen the crimps.
  7. Mr. Coffee DW13 Tubing Replacement: 7 단계, 이미지 1/1
    • Once the crimps are loosened, slide them down the tubing.
  8. Mr. Coffee DW13 Tubing Replacement: 8 단계, 이미지 1/2 Mr. Coffee DW13 Tubing Replacement: 8 단계, 이미지 2/2
    • Separate the tubing from the heating coil by grasping the tubing in one hand and the heating coil in the other and gently pulling apart.
  9. Mr. Coffee DW13 Tubing Replacement: 9 단계, 이미지 1/3 Mr. Coffee DW13 Tubing Replacement: 9 단계, 이미지 2/3 Mr. Coffee DW13 Tubing Replacement: 9 단계, 이미지 3/3
    • Gently pull on plastic tubing, freeing it from the coffee maker
    • One of the tubes has a red ball check valve in the middle. Be sure to note which hole it connects to.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Kinsie Ward
회원 가입일: 01/26/14
213 평판
안내서 1개 작성함
Cal Poly, Team 10-31, Maness Winter 2014 Cal Poly, Team 10-31, Maness Winter 2014 회원
CPSU-MANESS-W14S10G31
4 회원들
안내서 6개 작성하였습니다
댓글 8개
Great photos. I've done this on another mr coffee model twice. Once for lime buildup, once for a coffee ground clogging it. Make sure you are gentle with the soft tubing. I split the hose at one end. The clamps now barely covers the split, but I'm looking for a replacement tube and ball valve.
markvassmer - 답글
I did not have to detach the heating coil from the plate in order to remove the tubing.
I found that the check valve was clogged with debris on my unit. Blowing it out cleared the clog. My unit's check valve is built into the tube that goes from the reservoir to the coil, so I only had to remove that tube to solve my issue.
rulegit2000 - 답글
Where does the tube with the check valve attach?
latimert36@windstream.net
Thomas Latimer -
Water inlet tube from the tank on my model Mr. Coffee BVMC-SJX33GT.
Mark Vassmer -
MarkVassmer -- did you find a replacement tube and ball valve? If so, where?
jay_amor - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 37
전체 시간: 7,234
