주요 콘텐츠로 건너뛰기
Mt. Fury Roadmaster Pedal Replacement
필요한 것
  1. Mt. Fury Roadmaster Pedal Replacement, Pedal: 1 단계, 이미지 1/1
    • Flip the bicycle upside down so that the bicycle rests on the seat and handlebars. The bike should be able to stay standing on its own.
  2. Mt. Fury Roadmaster Pedal Replacement: 2 단계, 이미지 1/3 Mt. Fury Roadmaster Pedal Replacement: 2 단계, 이미지 2/3 Mt. Fury Roadmaster Pedal Replacement: 2 단계, 이미지 3/3
    • Locate the 15mm pedal nut, and position the crank arms for maximum leverage.
    • Using a 15mm open-end wrench, brace the opposite pedal with your other hand and remove the pedal nut from the crank arm.
    • A considerable amount of force may be required to break pedal nut free.
결론
To install new pedal, follow these instructions in reverse order.
Samantha Rawlins
회원 가입일: 01/21/14
476 평판
안내서 3개 작성하였습니다
Cal Poly, Team 1-40, Maness Winter 2014 Cal Poly, Team 1-40, Maness Winter 2014 회원
CPSU-MANESS-W14S1G40
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 10
전체 시간: 2,439
