주요 콘텐츠로 건너뛰기
Mt. Fury Roadmaster Rear Derailleur Replacement
필요한 것
  1. Mt. Fury Roadmaster Rear Derailleur Replacement, Rear Derailleur: 1 단계, 이미지 1개 중 1개
    • Flip the bicycle upside down so that the bicycle rests on the seat and handlebars. The bike should be able to stay standing on its own.
  2. Mt. Fury Roadmaster Rear Derailleur Replacement: 2 단계, 이미지 2개 중 1개 Mt. Fury Roadmaster Rear Derailleur Replacement: 2 단계, 이미지 2개 중 2개
    • Locate and remove the main axle nuts (both sides) with a 15mm open-end wrench.
  3. Mt. Fury Roadmaster Rear Derailleur Replacement: 3 단계, 이미지 2개 중 1개 Mt. Fury Roadmaster Rear Derailleur Replacement: 3 단계, 이미지 2개 중 2개
    • Pull the chain slack and remove the tire.
  4. Mt. Fury Roadmaster Rear Derailleur Replacement: 4 단계, 이미지 1개 중 1개
    • Locate and remove the rear phillips head screw on the sprocket to remove one side of chain guard.
  5. Mt. Fury Roadmaster Rear Derailleur Replacement: 5 단계, 이미지 2개 중 1개 Mt. Fury Roadmaster Rear Derailleur Replacement: 5 단계, 이미지 2개 중 2개
    • Rotate the derailleur arm forward to access the phillips head screw from the forwardmost sprocket. Remove the screw.
    • Be careful to hold the chain guard in place so the sprocket and washers don't fall out. (Chain guard is highlighted in red).
  6. Mt. Fury Roadmaster Rear Derailleur Replacement: 6 단계, 이미지 1개 중 1개
    • Locate and loosen the hex bolt that clamps the shifting cable.
  7. Mt. Fury Roadmaster Rear Derailleur Replacement: 7 단계, 이미지 1개 중 1개
    • Remove mounting screw that attaches the derailleur to the bicycle frame.
  8. Mt. Fury Roadmaster Rear Derailleur Replacement: 8 단계, 이미지 2개 중 1개 Mt. Fury Roadmaster Rear Derailleur Replacement: 8 단계, 이미지 2개 중 2개
    • Loosen the shifting cable tension adjustment nut and remove the cable from the derailleur assembly .
결론
To install new derailleur, follow these instructions in reverse order.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Monty Dodge Jr
회원 가입일: 01/22/14
669 평판
안내서 2개를 작성함
Cal Poly, Team 1-40, Maness Winter 2014 Cal Poly, Team 1-40, Maness Winter 2014 회원
CPSU-MANESS-W14S1G40
4 회원들
안내서 5개를 작성함
댓글 2개
Directions are simple clear and to the point. Excellent!
Paul J. Baker - 답글
Now how do you put it back?
Wendy Navarro - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 23
지난 30일: 42
전체 시간: 8,365
