주요 콘텐츠로 건너뛰기
Mt. Fury Roadmaster Tire Replacement
필요한 것
  1. Mt. Fury Roadmaster Tire Replacement, Inner Tube: 1 단계, 이미지 1/1
    • Flip the bicycle upside down so that the bicycle rests on the seat and handlebars. The bike should be able to stay standing on its own.
  2. Mt. Fury Roadmaster Tire Replacement: 2 단계, 이미지 1/1
    • Using a 15mm wrech, loosen the axial nut.
  3. Mt. Fury Roadmaster Tire Replacement: 3 단계, 이미지 1/2 Mt. Fury Roadmaster Tire Replacement: 3 단계, 이미지 2/2
    • Pull the chain slack and remove the tire.
  4. Mt. Fury Roadmaster Tire Replacement: 4 단계, 이미지 1/2 Mt. Fury Roadmaster Tire Replacement: 4 단계, 이미지 2/2
    • Insert the flat side of the tire lever between the inside edge of the rim and the seal of the tire.
    • Clip the tire lever to the nearest spoke.
  5. Mt. Fury Roadmaster Tire Replacement: 5 단계, 이미지 1/2 Mt. Fury Roadmaster Tire Replacement: 5 단계, 이미지 2/2
    • Insert the second tire lever next to first and slowly slide it along the outside edge of the rim until one side of the tire is off the rim.
  6. Mt. Fury Roadmaster Tire Replacement: 6 단계, 이미지 1/1
    • Re-insert the first tire lever to hook the opposite seam of the tire and repeat steps 3 through 5.
  7. Mt. Fury Roadmaster Tire Replacement: 7 단계, 이미지 1/1
    • Remove the cap from the inner tube, and pull the valve stem out of the rim.
결론
To install new inner tube, follow these instructions in reverse order.
다른 4명이 해당 안내서를 완성하였습니다.
Samantha Rawlins
회원 가입일: 01/21/14
476 평판
안내서 3개 작성하였습니다
Cal Poly, Team 1-40, Maness Winter 2014 Cal Poly, Team 1-40, Maness Winter 2014 회원
CPSU-MANESS-W14S1G40
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
Replace also means how to put it back together!
ellik - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 13
30일 전: 47
전체 시간: 6,814
