주요 콘텐츠로 건너뛰기
Munchkin Mozart Magic Cube Face plate Replacement
필요한 것
  1. Munchkin Mozart Magic Cube Face plate  Replacement, Face plate: 1 단계, 이미지 1/2 Munchkin Mozart Magic Cube Face plate  Replacement, Face plate: 1 단계, 이미지 2/2
    • Remove two 6 mm Phillips #2 screws on either side of the On/Off Plate.
  2. Munchkin Mozart Magic Cube Face plate  Replacement: 2 단계, 이미지 1/1
    • Remove the On/Off switch plate and save the screws so you can use them later to put the plate back on.
  3. Munchkin Mozart Magic Cube Face plate  Replacement: 3 단계, 이미지 1/1
    • Gently pull out the battery cartridge and if needed, replace the batteries with 3 AA alkaline batteries.
  4. Munchkin Mozart Magic Cube Face plate  Replacement: 4 단계, 이미지 1/1
    • Starting with the yellow face, insert the metal spudger between the yellow face and the white frame, prying the frame apart.
  5. Munchkin Mozart Magic Cube Face plate  Replacement: 5 단계, 이미지 1/1
    • Insert the metal spudger in the space created by the plastic opening tool between the frame and face of the cube.
    • Pry the cube face from the frame.
  6. Munchkin Mozart Magic Cube Face plate  Replacement: 6 단계, 이미지 1/1
    • After removing the square plates, you can unscrew the screws underneath.
    • Remove four 6 mm Phillips #2 screws, located on the sides.
  7. Munchkin Mozart Magic Cube Face plate  Replacement: 7 단계, 이미지 1/1
    • Remove the rubber corners by simply pulling them off.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ibrahim Aldairem
회원 가입일: 09/01/15
335 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-4, Sullivan Fall 2015 USF Tampa, Team 1-4, Sullivan Fall 2015 회원
USFT-SULLIVAN-F15S1G4
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 1,184
