주요 콘텐츠로 건너뛰기
Munchkin Mozart Magic Cube Sound Button Replacement
필요한 것
  1. Munchkin Mozart Magic Cube Sound Button Replacement, Face plate: 1 단계, 이미지 2개 중 1개 Munchkin Mozart Magic Cube Sound Button Replacement, Face plate: 1 단계, 이미지 2개 중 2개
    • Remove two 6 mm Phillips #2 screws on either side of the On/Off Plate.
  2. Munchkin Mozart Magic Cube Sound Button Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the On/Off switch plate and save the screws so you can use them later to put the plate back on.
  3. Munchkin Mozart Magic Cube Sound Button Replacement: 3 단계, 이미지 1개 중 1개
    • Gently pull out the battery cartridge and if needed, replace the batteries with 3 AA alkaline batteries.
  4. Munchkin Mozart Magic Cube Sound Button Replacement: 4 단계, 이미지 1개 중 1개
    • Starting with the yellow face, insert the metal spudger between the yellow face and the white frame, prying the frame apart.
  5. Munchkin Mozart Magic Cube Sound Button Replacement: 5 단계, 이미지 1개 중 1개
    • Insert the metal spudger in the space created by the plastic opening tool between the frame and face of the cube.
    • Pry the cube face from the frame.
  6. Munchkin Mozart Magic Cube Sound Button Replacement: 6 단계, 이미지 1개 중 1개
    • After removing the square plates, you can unscrew the screws underneath.
    • Remove four 6 mm Phillips #2 screws, located on the sides.
  7. Munchkin Mozart Magic Cube Sound Button Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the rubber corners by simply pulling them off.
  8. Munchkin Mozart Magic Cube Sound Button Replacement, Sound Button: 8 단계, 이미지 1개 중 1개
    • Flip the frame over so that green motherboard over so that the LED is face down and the brown side of the motherboard is face up using the Jimmy to remove the glue connecting the motherboard to the white frame.
  9. Munchkin Mozart Magic Cube Sound Button Replacement: 9 단계, 이미지 1개 중 1개
    • Slide the motherboard out of the frame.
  10. Munchkin Mozart Magic Cube Sound Button Replacement: 10 단계, 이미지 2개 중 1개 Munchkin Mozart Magic Cube Sound Button Replacement: 10 단계, 이미지 2개 중 2개
    • To remove the button use your fingers or forceps to remove the gray rubber button piece on the green side of the motherboard.
결론
작성자
4다른 기여자 명과 함께
Nikolas Soulandros
회원 가입일: 08/27/15
291 평판
안내서 2개를 작성함
USF Tampa, Team 1-4, Sullivan Fall 2015 USF Tampa, Team 1-4, Sullivan Fall 2015 회원
USFT-SULLIVAN-F15S1G4
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 9
전체 시간: 806
