주요 콘텐츠로 건너뛰기
Munchkinz External Casing Removal
필요한 것
  1. Munchkinz External Casing Removal, Opening Device: 1 단계, 이미지 1/1
    • Insert spudger into the USB Micro slot and pry the case apart.
    • Be careful not to go too deep and bend the prong inside the Micro USB port.
  2. Munchkinz External Casing Removal, Pry Device Apart: 2 단계, 이미지 1/2 Munchkinz External Casing Removal, Pry Device Apart: 2 단계, 이미지 2/2
    • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
    • Gently separate the case so none of the cords inside are disconnected
  3. Munchkinz External Casing Removal, Separated Device: 3 단계, 이미지 1/1
    • After prying the device apart, it should look like this.
결론
Austin Oliveira
회원 가입일: 02/05/15
204 평판
안내서 2개 작성하였습니다
UW Tacoma, Team 3-6, Rose Winter 2015 UW Tacoma, Team 3-6, Rose Winter 2015 회원
UWT-ROSE-W15S3G6
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 161
