필요한 것
Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
Use the precision tweezers to gently disconnect the camera ribbon that is connected to the motherboard.
Use the slim plastic opening tool to remove the speaker from its position on the case.
Un-solder the red and black speaker wires that are connected to the motherboard
Un-solder the yellow, red, and black wires that connect the volume module to the motherboard.
Use the wide plastic opening tool to slowly pry each side of the battery up.
Carefully lift up the motherboard. Your accessory parts such as battery, speaker, volume button assembly, and camera wires will be disconnected, not connected, like in this picture.
