주요 콘텐츠로 건너뛰기
MyFirst Camera Insta 2 teardown
필요한 것
  1. MyFirst Camera Insta 2 teardown, Prepare teardown: 1 단계, 이미지 3개 중 1개 MyFirst Camera Insta 2 teardown, Prepare teardown: 1 단계, 이미지 3개 중 2개 MyFirst Camera Insta 2 teardown, Prepare teardown: 1 단계, 이미지 3개 중 3개
    • Remove SD card, carry strap and paper cartridge
  2. MyFirst Camera Insta 2 teardown, Lift the front panel: 2 단계, 이미지 2개 중 1개 MyFirst Camera Insta 2 teardown, Lift the front panel: 2 단계, 이미지 2개 중 2개
    • Remove the front panel
    • The panel is simply clipped and can be declipped easily by using a mediator as lever
  3. MyFirst Camera Insta 2 teardown, Unscrew front panel: 3 단계, 이미지 2개 중 1개 MyFirst Camera Insta 2 teardown, Unscrew front panel: 3 단계, 이미지 2개 중 2개
    • The toy is closed by 5 Philips-head screws, size 0
    • Unscrew them all and open the product
  4. MyFirst Camera Insta 2 teardown, Remove the cartridge-holding piece: 4 단계, 이미지 3개 중 1개 MyFirst Camera Insta 2 teardown, Remove the cartridge-holding piece: 4 단계, 이미지 3개 중 2개 MyFirst Camera Insta 2 teardown, Remove the cartridge-holding piece: 4 단계, 이미지 3개 중 3개
    • The white piece is held by 4 Philips-head screws
    • Unscrew the three screws you can already access
    • Unscrew the selfie camera, held by two smaller screws
    • Under the camera, unscrew the forth screw holding the piece
  5. MyFirst Camera Insta 2 teardown, Disconnect the screen: 5 단계, 이미지 1개 중 1개
    • Remove the glue around the screen connector
    • Disconnect by lifting the connector clip upward
  6. MyFirst Camera Insta 2 teardown, Unscrew the PCB: 6 단계, 이미지 2개 중 1개 MyFirst Camera Insta 2 teardown, Unscrew the PCB: 6 단계, 이미지 2개 중 2개
    • The board is held by the 4 previously removed screws, plus another screw close to USB connector
    • Once all those are removed and the screen is disconnected, pull the card from its compartment by sliding it on the side opposite to USB connector
  7. MyFirst Camera Insta 2 teardown, Teardown view: 7 단계, 이미지 3개 중 1개 MyFirst Camera Insta 2 teardown, Teardown view: 7 단계, 이미지 3개 중 2개 MyFirst Camera Insta 2 teardown, Teardown view: 7 단계, 이미지 3개 중 3개
    • Unknown microcontrolleur, QFP80 package , with reference "2104G-91"
    • Princeton Technology PT5139-HT motor driver
    • Syncrown PT48D 2-inch thermal printer
    • Thinksum 123050 7.4V 750mAh li-ion battery
    • Screen, speaker, two photo modules
결론
To reassemble your device, follow the unmounting instructions in reverse order.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
Eve Redero
회원 가입일: 02/28/22
3,101 평판
안내서 10개를 작성함
1가이드 댓글
Hi,
Where can I purchase a replacement lcd screen for the “myfirst camera insta 2” model no. FC2401
Christian Juul Henriksen - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 37
전체 시간: 655
