주요 콘텐츠로 건너뛰기
N-Strike Nite Finder EX-3 Battery Replacement
필요한 것
  1. N-Strike Nite Finder EX-3 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • The batteries are located in the handle of the blaster.
    • The base plate is held in place with a single phillips head, 8.2 mm screw. Remove this screw and remove the base plate to access the battery compartment.
  2. N-Strike Nite Finder EX-3 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Once the batteries have been removed, you can check to see if they have any charge left in them with a battery tester.
    • If they are in fact dead, replace them with standard AA type batteries in the correct orientation.
결론
작성자
5다른 기여자 명과 함께
Nicholas Samokyszyn
회원 가입일: 02/24/14
359 평판
안내서 3개를 작성함
Michigan Tech, Team 5-8, Lauer Spring 2014 Michigan Tech, Team 5-8, Lauer Spring 2014 회원
MTU-LAUER-S14S5G8
3 회원들
안내서 13개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 18
전체 시간: 2,916
