주요 콘텐츠로 건너뛰기
N-Strike Nite Finder EX-3 Trigger Replacement
필요한 것
  1. N-Strike Nite Finder EX-3 Trigger Replacement, Trigger: 1 단계, 이미지 1/1
    • Place the blaster upside down on the table, and remove the screw in the bottom of the handle.
    • Remove the battery door and take the batteries out.
  2. N-Strike Nite Finder EX-3 Trigger Replacement: 2 단계, 이미지 1/3 N-Strike Nite Finder EX-3 Trigger Replacement: 2 단계, 이미지 2/3 N-Strike Nite Finder EX-3 Trigger Replacement: 2 단계, 이미지 3/3
    • Set the blaster on its side with the screws facing up (the blaster will be placed on its left side). Remove all 14 phillips head, 8.2 mm screws and set them aside.
    • Lift the side of the blaster off exposing its internal parts.
  3. N-Strike Nite Finder EX-3 Trigger Replacement: 3 단계, 이미지 1/2 N-Strike Nite Finder EX-3 Trigger Replacement: 3 단계, 이미지 2/2
    • Remove the phillips head, 10.2 mm screw holding the trigger in place.
  4. N-Strike Nite Finder EX-3 Trigger Replacement: 4 단계, 이미지 1/1
    • Remove the trigger by pulling the piece straight up.
    • Caution: Do not let the spring fly off the spring
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kyle Schober
회원 가입일: 02/24/14
640 평판
안내서 5개 작성하였습니다
Michigan Tech, Team 5-8, Lauer Spring 2014 Michigan Tech, Team 5-8, Lauer Spring 2014 회원
MTU-LAUER-S14S5G8
3 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 6
전체 시간: 1,764
