주요 콘텐츠로 건너뛰기
N-Strike Nite Finder EX-3 Wire Replacement Guide
필요한 것
  1. N-Strike Nite Finder EX-3 Wire Replacement Guide, Wire: 1 단계, 이미지 1개 중 1개
    • Place the blaster upside down on the table, and remove the screw in the bottom of the handle.
    • Remove the battery door and take the batteries out.
  2. N-Strike Nite Finder EX-3 Wire Replacement Guide: 2 단계, 이미지 3개 중 1개 N-Strike Nite Finder EX-3 Wire Replacement Guide: 2 단계, 이미지 3개 중 2개 N-Strike Nite Finder EX-3 Wire Replacement Guide: 2 단계, 이미지 3개 중 3개
    • Set the blaster on its side with the screws facing up (the blaster will be placed on its left side). Remove all 14 phillips head, 8.2 mm screws and set them aside.
    • Lift the side of the blaster to expose its internal parts.
  3. N-Strike Nite Finder EX-3 Wire Replacement Guide: 3 단계, 이미지 1개 중 1개
    • Visually inspect all the wires in order to find the break, fray, or any other problem.
    • Locate the end connections of the affected wire.
  4. N-Strike Nite Finder EX-3 Wire Replacement Guide: 4 단계, 이미지 1개 중 1개
    • Use a hot soldering iron to melt the solder at one end of the wire until the wire can be pulled free from the connection.
    • Repeat on the other end of the connection to remove the wire from the blaster.
    • (End points marked on image are for the black wire)
결론
작성자
5다른 기여자 명과 함께
Kyle Schober
회원 가입일: 02/24/14
640 평판
안내서 5개를 작성함
Michigan Tech, Team 5-8, Lauer Spring 2014 Michigan Tech, Team 5-8, Lauer Spring 2014 회원
MTU-LAUER-S14S5G8
3 회원들
안내서 13개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 14
전체 시간: 1,073
