주요 콘텐츠로 건너뛰기
Changing SSD disk why! N131WU
필요한 것
  1. Changing SSD disk why! N131WU, Remove the Screws: 1 단계, 이미지 1/1
    • Remove the case screws (red) and the keyboard screws (green).
    • Be sure not to lose these screws. You will need them to reassemble your laptop.
  2. Changing SSD disk why! N131WU, Remove the Keyboard: 2 단계, 이미지 1/3 Changing SSD disk why! N131WU, Remove the Keyboard: 2 단계, 이미지 2/3 Changing SSD disk why! N131WU, Remove the Keyboard: 2 단계, 이미지 3/3
    • Using the hole provided under the case (see picture), push the keyboard out using a thin screwdriver or some other solid object.
    • Hold onto the keyboard as you push the keyboard so as not to damage the two cables still attached.
  3. Changing SSD disk why! N131WU, Remove Keyboard Connections: 3 단계, 이미지 1/3 Changing SSD disk why! N131WU, Remove Keyboard Connections: 3 단계, 이미지 2/3 Changing SSD disk why! N131WU, Remove Keyboard Connections: 3 단계, 이미지 3/3
    • (Blue Cable) Push up on the thin black portion on the connector and gently pull out the blue ribbon cable until it comes out.
    • (Orange Cable) Remove the orange cable by sliding the gray part of the connector towards the screen, then gently pull on the ribbon cable.
  4. Changing SSD disk why! N131WU, Remove the upper screws: 4 단계, 이미지 1/2 Changing SSD disk why! N131WU, Remove the upper screws: 4 단계, 이미지 2/2
    • Unscrew the three screws that were under the keyboard. Be sure to hold onto these.
    • After these are removed, you can now remove the lower part of the case from the rest of the computer.
  5. Changing SSD disk why! N131WU, Remove the SSD: 5 단계, 이미지 1/3 Changing SSD disk why! N131WU, Remove the SSD: 5 단계, 이미지 2/3 Changing SSD disk why! N131WU, Remove the SSD: 5 단계, 이미지 3/3
    • Remove the screw holding in the ssd.
    • Carefully remove the SSD from the connector.
결론
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Felice Suglia
회원 가입일: 06/15/13
30,908 평판
안내서 264개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 15
전체 시간: 511
