주요 콘텐츠로 건너뛰기
Fix Your Stuff
Right to Repair
Parts & Tools
  1. Remove the case screws (red) and the keyboard screws (green).
    • Remove the case screws (red) and the keyboard screws (green).
    • Be sure not to lose these screws. You will need them to reassemble your laptop.
  2. Using the hole provided under the case (see picture), push the keyboard out using a thin screwdriver or some other solid object. Using the hole provided under the case (see picture), push the keyboard out using a thin screwdriver or some other solid object. Using the hole provided under the case (see picture), push the keyboard out using a thin screwdriver or some other solid object.
    • Using the hole provided under the case (see picture), push the keyboard out using a thin screwdriver or some other solid object.
  3. (Blue Cable) Push up on the thin black portion on the connector and gently pull out the blue ribbon cable until it comes out. (Orange Cable) Remove the orange cable by sliding the gray part of the connector towards the screen, then gently pull on the ribbon cable. (Orange Cable) Remove the orange cable by sliding the gray part of the connector towards the screen, then gently pull on the ribbon cable.
    • (Blue Cable) Push up on the thin black portion on the connector and gently pull out the blue ribbon cable until it comes out.
    • (Orange Cable) Remove the orange cable by sliding the gray part of the connector towards the screen, then gently pull on the ribbon cable.
  4. Unscrew the three screws that were under the keyboard. Be sure to hold onto these. After these are removed, you can now remove the lower part of the case from the rest of the computer.
    • Unscrew the three screws that were under the keyboard. Be sure to hold onto these.
    • After these are removed, you can now remove the lower part of the case from the rest of the computer.
결론
To reassemble your laptop, follow the instructions in reverse.
다른 4명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Felice Suglia
회원 가입일: 2013년 06월 15일
14,784 평판
안내서 150개 작성하였습니다
Valable aussi pour le portable CLEVO N141ZU
Thomas B - 답글
Merci nous avons ajouté les autres modèles compatibles
Ekimia -
Bonjour MANIP pour sortir clavier, ce dernier ne vient pas ! ça tient par vis centrale VERTE impossible de le sortir sur CLEVO N141ZU précision toutes les vis sont sorties ( 10 rouges et 2 vertes ça retient vers intérieur a moins de tout casser ! ) a plus Merci Raymond Feix
Raymond Feix - 답글
Si les 2 vertes sont bien retirées , il n y a aucun risque à pousser
Ekimia -
Bonjour, une fois toutes les vis retirées, il faut vraiment appuyer assez fortement pour déclipser le clavier sur un côté. Pour la suite du déclipsage, il faut reprendre délicatement depuis dessus en faisant le tour du clavier depuis la partie déclipsée.
Bonne chance!
Felice Suglia - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 34
전체 시간: 294
