주요 콘텐츠로 건너뛰기
NABI XD Motherboard Replacement
필요한 것
  1. NABI XD Motherboard Replacement, Rear panel: 1 단계, 이미지 1/2 NABI XD Motherboard Replacement, Rear panel: 1 단계, 이미지 2/2
    • Use the plastic opening tool at the top left corner seam, then pry the corner apart.
  2. NABI XD Motherboard Replacement: 2 단계, 이미지 1/1
    • Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
    • There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
    • Go around the NABI XD and separate the rear panel from the device.
  3. NABI XD Motherboard Replacement, Battery: 3 단계, 이미지 1/2 NABI XD Motherboard Replacement, Battery: 3 단계, 이미지 2/2
    • Place your fingernails on both sides of the connector and pull it straight back away from the holder.
  4. NABI XD Motherboard Replacement: 4 단계, 이미지 1/1
    • Battery is glued to the base, lift carefully.
    • To remove battery, lift the battery up from the motherboard.
  5. NABI XD Motherboard Replacement, Charging port: 5 단계, 이미지 1/2 NABI XD Motherboard Replacement, Charging port: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Remove the two 4mm Phillips screws with the PH#0 screwdriver.
    • Disconnect the left (L) speaker wire from the charging port by grabbing it on both sides with the tweezers and pulling straight back.
  6. NABI XD Motherboard Replacement: 6 단계, 이미지 1/1
    • Use your fingernails or a spudger to flip up the small retaining flap, then pull the ribbon straight back to remove
    • Lift the charging port from the NABI XD.
  7. NABI XD Motherboard Replacement, Motherboard: 7 단계, 이미지 1/3 NABI XD Motherboard Replacement, Motherboard: 7 단계, 이미지 2/3 NABI XD Motherboard Replacement, Motherboard: 7 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • To remove the marked ribbons, use your fingernails or a spudger to lift up small tab
    • Use the Precision Tweezers to gently pull the ribbons straight out of the connectors.
    • You need to remove 4 ribbons
  8. NABI XD Motherboard Replacement: 8 단계, 이미지 1/3 NABI XD Motherboard Replacement: 8 단계, 이미지 2/3 NABI XD Motherboard Replacement: 8 단계, 이미지 3/3
    • Disconnect the camera by lifting the ribbon straight up. Also disconnect the remaining ribbon by lifting up gently.
    • To disconnect antenna wire, use the tweezers to pry connector straight from the board.
  9. NABI XD Motherboard Replacement: 9 단계, 이미지 1/2 NABI XD Motherboard Replacement: 9 단계, 이미지 2/2
    • Disconnect the Right speaker by grabbing the wire head by its sides and pulling it back from the connector.
  10. NABI XD Motherboard Replacement: 10 단계, 이미지 1/2 NABI XD Motherboard Replacement: 10 단계, 이미지 2/2
    • Remove the four 4mm Phillips screws with the PH#0 screwdriver.
  11. NABI XD Motherboard Replacement: 11 단계, 이미지 1/1
    • Lift the motherboard up away from the Nabi XD.
결론
Marissa Schiereck
회원 가입일: 09/15/16
638 평판
안내서 6개 작성하였습니다
USF Tampa, Team 17-2, Blackwell Fall 2016 USF Tampa, Team 17-2, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S17G2
3 회원들
안내서 12개 작성하였습니다
댓글 한 개
Donde puedo conprar la pelicula de la tables o el displey y tatil
maria-201309 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 14
전체 시간: 251
