주요 콘텐츠로 건너뛰기
NABI XD Rear panel Replacement
필요한 것
  1. NABI XD Rear panel Replacement, Rear panel: 1 단계, 이미지 1/2 NABI XD Rear panel Replacement, Rear panel: 1 단계, 이미지 2/2
    • Use the plastic opening tool at the top left corner seam, then pry the corner apart.
  2. NABI XD Rear panel Replacement: 2 단계, 이미지 1/1
    • Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
    • There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
    • Go around the NABI XD and separate the rear panel from the device.
결론
Marissa Schiereck
회원 가입일: 09/15/16
638 평판
안내서 6개 작성하였습니다
USF Tampa, Team 17-2, Blackwell Fall 2016 USF Tampa, Team 17-2, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S17G2
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 10
전체 시간: 197
