주요 콘텐츠로 건너뛰기
NEC LCD1770NX Power Circuit Board Replacement
필요한 것
  1. NEC LCD1770NX Power Circuit Board Replacement, Stand: 1 단계, 이미지 2개 중 1개 NEC LCD1770NX Power Circuit Board Replacement, Stand: 1 단계, 이미지 2개 중 2개
    • Place the monitor face down on a clean, flat surface.
  2. NEC LCD1770NX Power Circuit Board Replacement: 2 단계, 이미지 2개 중 1개 NEC LCD1770NX Power Circuit Board Replacement: 2 단계, 이미지 2개 중 2개
    • Firmly remove the back panel of the stand by pulling it up and away from the monitor.
  3. NEC LCD1770NX Power Circuit Board Replacement: 3 단계, 이미지 2개 중 1개 NEC LCD1770NX Power Circuit Board Replacement: 3 단계, 이미지 2개 중 2개
    • Unscrew the two 6mm Phillips PH2 screws to detach the stand enclosure from the stand.
  4. NEC LCD1770NX Power Circuit Board Replacement: 4 단계, 이미지 2개 중 1개 NEC LCD1770NX Power Circuit Board Replacement: 4 단계, 이미지 2개 중 2개
    • Firmly grasp the stand enclosure with your hand and slide it to base of stand.
  5. NEC LCD1770NX Power Circuit Board Replacement: 5 단계, 이미지 1개 중 1개
    • Unscrew the two 14.5mm Phillips PH2 screws holding the stand to the monitor.
  6. NEC LCD1770NX Power Circuit Board Replacement: 6 단계, 이미지 2개 중 1개 NEC LCD1770NX Power Circuit Board Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the the stand straight up to remove it.
  7. NEC LCD1770NX Power Circuit Board Replacement, Monitor Enclosure: 7 단계, 이미지 3개 중 1개 NEC LCD1770NX Power Circuit Board Replacement, Monitor Enclosure: 7 단계, 이미지 3개 중 2개 NEC LCD1770NX Power Circuit Board Replacement, Monitor Enclosure: 7 단계, 이미지 3개 중 3개
    • Place the monitor screen face up.
    • Pull the frame off by placing your fingers on the inside of the frame and pulling out and up, the frame should snap off.
    • Continue your way around the screen.
  8. NEC LCD1770NX Power Circuit Board Replacement: 8 단계, 이미지 3개 중 1개 NEC LCD1770NX Power Circuit Board Replacement: 8 단계, 이미지 3개 중 2개 NEC LCD1770NX Power Circuit Board Replacement: 8 단계, 이미지 3개 중 3개
    • Unscrew the two 7mm screws from the bottom of the button assembly.
    • Do not pull the button assembly out too quickly or with too much force! Damage to the wires can occur.
    • Pull the button assembly out a few inches and unplug the colored cables.
  9. NEC LCD1770NX Power Circuit Board Replacement: 9 단계, 이미지 2개 중 1개 NEC LCD1770NX Power Circuit Board Replacement: 9 단계, 이미지 2개 중 2개
    • Unscrew the gold colored 7mm Phillips PH000 screw holding the button assembly to the monitor.
    • Remove the button assembly from the monitor.
  10. NEC LCD1770NX Power Circuit Board Replacement: 10 단계, 이미지 1개 중 1개
    • With the monitor face-down, unscrew the 5 7mm Phillips PH2 screws around the outside of the enclosure.
  11. NEC LCD1770NX Power Circuit Board Replacement: 11 단계, 이미지 3개 중 1개 NEC LCD1770NX Power Circuit Board Replacement: 11 단계, 이미지 3개 중 2개 NEC LCD1770NX Power Circuit Board Replacement: 11 단계, 이미지 3개 중 3개
    • Unscrew the 2 14.5mm Phillips PH2 screws located on the raised center of the enclosure.
    • Carefully pull the enclosure off the monitor.
  12. NEC LCD1770NX Power Circuit Board Replacement: 12 단계, 이미지 2개 중 1개 NEC LCD1770NX Power Circuit Board Replacement: 12 단계, 이미지 2개 중 2개
    • Unscrew the 10 5mm Philips PH2 screws holding the metal casing to the monitor.
  13. NEC LCD1770NX Power Circuit Board Replacement: 13 단계, 이미지 2개 중 1개 NEC LCD1770NX Power Circuit Board Replacement: 13 단계, 이미지 2개 중 2개
    • Pull the the metal casing off of the monitor to reveal the motherboards.
  14. NEC LCD1770NX Power Circuit Board Replacement, Power Circuit Board: 14 단계, 이미지 3개 중 1개 NEC LCD1770NX Power Circuit Board Replacement, Power Circuit Board: 14 단계, 이미지 3개 중 2개 NEC LCD1770NX Power Circuit Board Replacement, Power Circuit Board: 14 단계, 이미지 3개 중 3개
    • Make a note or use a pen to mark which plugs correspond to which colors. (Pink or Blue)
    • Remove the four plugs on the brown circuit board by pulling up on the tabs and wiggling them out. You could also use a spudger to help you lift little clips holding them in.
  15. NEC LCD1770NX Power Circuit Board Replacement: 15 단계, 이미지 3개 중 1개 NEC LCD1770NX Power Circuit Board Replacement: 15 단계, 이미지 3개 중 2개 NEC LCD1770NX Power Circuit Board Replacement: 15 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Large Needle Nose Pliers
    • Locate the several multi-wire connectors on the board.
    • These connect several parts of each board together and consist of several different colors of wires. There is also a zip-tie holding the two sets of wires together that you can cut if it is getting in your way.
    • Disconnect the three plastic connectors from the blue colored boards by pulling them up while wiggling them.
    • Some force is necessary, it may also help to use the Large Needle Nose Pliers.
  16. NEC LCD1770NX Power Circuit Board Replacement: 16 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Phillips #1 Screwdriver
    $5.49
    • Locate the large black power plug.
    • Using a Phillips #1 Screwdriver, unscrew the two 8mm colts holding the black tabs to the metal frame.
  17. NEC LCD1770NX Power Circuit Board Replacement: 17 단계, 이미지 1개 중 1개
    • Locate and remove the gold colored 10mm Philips screw located near the black power plug. It holds in a wire that connects to the power plug.
  18. NEC LCD1770NX Power Circuit Board Replacement: 18 단계, 이미지 2개 중 1개 NEC LCD1770NX Power Circuit Board Replacement: 18 단계, 이미지 2개 중 2개
    • Remove 5 8mm Phillip1 screws, with a Philips 1 screwdriver, located in various places on the board.
  19. NEC LCD1770NX Power Circuit Board Replacement: 19 단계, 이미지 2개 중 1개 NEC LCD1770NX Power Circuit Board Replacement: 19 단계, 이미지 2개 중 2개
    • Lift the brown power supply board off of the frame and set it aside.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Charlie Mohr
회원 가입일: 10/21/13
359 평판
안내서 3개를 작성함
Cal Poly, Team 11-36, Amido Fall 2013 Cal Poly, Team 11-36, Amido Fall 2013 회원
CPSU-AMIDO-F13S11G36
5 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 1,687
