주요 콘텐츠로 건너뛰기
NERF Doomlands 2169 Lawbringer Blaster Catch Spring Replacement
필요한 것
  1. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement, Catch Spring: 1 단계, 이미지 1/2 NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement, Catch Spring: 1 단계, 이미지 2/2
    • Locate and remove all 14 screws of the outer case and gently remove it avoiding any damage.
  2. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: 2 단계, 이미지 1/1
    • Remove the three screws attached to the trigger mechanism of the gun.
    • Be careful when removing the rotating cartridge from the case, as the fulcrum attaching it to the trigger mechanism will fall out.
  3. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: 3 단계, 이미지 1/1
    • Remove the exterior spring from the sliding mechanism and re-position the gun on its opposite side.
  4. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: 4 단계, 이미지 1/1
    • Remove the three screws holding the trigger plate in place, then remove the plate carefully.
  5. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: 5 단계, 이미지 1/1
    • Remove the spring and trigger mechanism from the gun, and set aside.
  6. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: 6 단계, 이미지 1/1
    • This is where the spring load mechanism is located, be cautious not to damage. If the spring separates from the gun, reattach it using a screwdriver end.
    • Carefully slide out the big spring and fit in your replacement (thin-coil end coiled around the orange plastic)
  7. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: 7 단계, 이미지 1/1
    • A second set of hands would be useful during this step. Make sure the orange slide is above the spring.
    • Keep tension on the spring and begin sliding the new coil spring into the trigger mechanism.
  8. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: 8 단계, 이미지 1/1
    • Reconnect the spring to the orange slider, and connect the orange slider to the grey hook.
  9. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: 9 단계, 이미지 1/2 NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: 9 단계, 이미지 2/2
    • Slide the orange supporting piece into the crevice below the air chamber.
    • Slide the rotating cartridge back into place
  10. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: 10 단계, 이미지 1/2 NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: 10 단계, 이미지 2/2
    • Look to the beginning of this guide for help to reassemble this gun.
    • Carefully reassemble the Nerf Law bringer in the same order you took it apart. Carefully reattach the 3 screws that seal the air chamber.
    • Reattach the other plastic half of the gun. Tighten the screws and you're done.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Daniel Perriello
회원 가입일: 11/04/15
134 평판
안내서 1개 작성함
University of Maine, Team 1-4, Diaz Fall 2015 University of Maine, Team 1-4, Diaz Fall 2015 회원
UMAINE-DIAZ-F15S1G4
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 1,920
