주요 콘텐츠로 건너뛰기
NERF Doomlands 2169 Lawbringer Blaster Spring Replacement
필요한 것
  1. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement, Spring: 1 단계, 이미지 1/2 NERF Doomlands 2169 Lawbringer Blaster Spring Replacement, Spring: 1 단계, 이미지 2/2
    • Remove sixteen screws from the outer case.
    • Remove the outer case from the rest of the device.
  2. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: 2 단계, 이미지 1/1
    • Remove the three screws attached to the trigger mechanism of the gun.
    • Potential for device damage: Be careful when removing the rotating cartridge from the case, as the fulcrum attaching it to the trigger mechanism will fall out!
  3. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: 3 단계, 이미지 1/1
    • Remove the exterior spring from the sliding mechanism and rotate the gun to the opposite side.
  4. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: 4 단계, 이미지 1/2 NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: 4 단계, 이미지 2/2
    • Remove the three screws holding the trigger plate in place, then remove the plate carefully.
  5. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: 5 단계, 이미지 1/1
    • Remove the spring and trigger mechanism from the gun and set aside.
  6. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: 6 단계, 이미지 1/1
    • Carefully slide out the big spring and fit in your replacement (the thin-coil end is coiled around the orange plastic).
    • Potential for device damage: This is where the spring load mechanism is located. Be cautious not to damage. If the spring separates from the gun, reattach it using a screwdriver end.
  7. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: 7 단계, 이미지 1/1
    • Keep tension on the spring and begin sliding the new coil spring into the trigger mechanism.
    • Make sure the orange slide is above the spring. A second set of hands would be useful during this step.
  8. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: 8 단계, 이미지 1/1
    • Reconnect the spring to the orange slider and connect the orange slider to the grey hook.
  9. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: 9 단계, 이미지 1/1
    • Slide the orange supporting piece into the crevice below the air chamber.
  10. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: 10 단계, 이미지 1/1
    • Slide the rotating cartridge back into place.
  11. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: 11 단계, 이미지 1/1
    • Carefully reassemble the NERF Lawbringer in the same order you took it apart. Carefully reattach the three screws that seal the air chamber.
  12. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: 12 단계, 이미지 1/1
    • Reattach the other plastic half of the gun. Tighten the screws and you're done.
결승점
Georgia Slack
회원 가입일: 10/13/16
113 평판
안내서 1개 작성함
University of Maine, Team 1-5, Diaz Fall 2016 University of Maine, Team 1-5, Diaz Fall 2016 회원
UMAINE-DIAZ-F16S1G5
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 9
전체 시간: 971
