주요 콘텐츠로 건너뛰기
NIkon Coolpix A900 Lens Replacement
필요한 것
  1. NIkon Coolpix A900 Lens Replacement, Battery: 1 단계, 이미지 1/1
    • Orient the camera so that it is upside down, with the lens facing towards you.
  2. NIkon Coolpix A900 Lens Replacement: 2 단계, 이미지 1/2 NIkon Coolpix A900 Lens Replacement: 2 단계, 이미지 2/2
    • Slide the battery door lock left to unlock it.
    • The battery door will automatically open.
  3. NIkon Coolpix A900 Lens Replacement: 3 단계, 이미지 1/2 NIkon Coolpix A900 Lens Replacement: 3 단계, 이미지 2/2
    • Slide the yellow tab up to release the battery.
    • To re-insert a battery, slide the battery back in until the yellow tab locks it in place.
    • There is a diagram on the opposite side of the battery compartment to help you orient the battery correctly.
  4. NIkon Coolpix A900 Lens Replacement, Rear Case: 4 단계, 이미지 1/3 NIkon Coolpix A900 Lens Replacement, Rear Case: 4 단계, 이미지 2/3 NIkon Coolpix A900 Lens Replacement, Rear Case: 4 단계, 이미지 3/3
    • Orient the camera upside down, with the lens facing away from you.
    • Remove the two 3mm Phillips #00 screws from the right.
    • Remove the two 3.4mm Phillips #00 screws from the left.
  5. NIkon Coolpix A900 Lens Replacement: 5 단계, 이미지 1/3 NIkon Coolpix A900 Lens Replacement: 5 단계, 이미지 2/3 NIkon Coolpix A900 Lens Replacement: 5 단계, 이미지 3/3
    • Turn the camera on its side, with the lens facing away from you.
    • Remove the 3.4mm Phillips #00 screw. Repeat this for the opposite side of the camera.
  6. NIkon Coolpix A900 Lens Replacement: 6 단계, 이미지 1/3 NIkon Coolpix A900 Lens Replacement: 6 단계, 이미지 2/3 NIkon Coolpix A900 Lens Replacement: 6 단계, 이미지 3/3
    • Place the camera upright with the lens facing away from you.
    • Move the monitor down, and remove two 4.4 mm screws.
  7. NIkon Coolpix A900 Lens Replacement: 7 단계, 이미지 1/2 NIkon Coolpix A900 Lens Replacement: 7 단계, 이미지 2/2
    • Remove the two black 2.5 mm screws from the monitor bracket.
  8. NIkon Coolpix A900 Lens Replacement: 8 단계, 이미지 1/2 NIkon Coolpix A900 Lens Replacement: 8 단계, 이미지 2/2
    • Return the monitor to the closed position.
    • Gently open the rear case.
    • You may need opening tools to help separate the rear case.
    • Be careful when opening the rear case to not damage the ribbon connectors.
  9. NIkon Coolpix A900 Lens Replacement: 9 단계, 이미지 1/3 NIkon Coolpix A900 Lens Replacement: 9 단계, 이미지 2/3 NIkon Coolpix A900 Lens Replacement: 9 단계, 이미지 3/3
    • Place the camera lens down, while supporting the rear case.
    • Unlock the two ribbons by using your finger to lift the plastic hinge on the ribbon connector.
    • With the ribbons disconnected, you can now remove the rear case.
  10. NIkon Coolpix A900 Lens Replacement, Lens: 10 단계, 이미지 1/3 NIkon Coolpix A900 Lens Replacement, Lens: 10 단계, 이미지 2/3 NIkon Coolpix A900 Lens Replacement, Lens: 10 단계, 이미지 3/3
    • Place the camera in front of you with the lens facing down.
    • On the top right, remove the 4.5 mm Phillips #00 screw holding the input shield.
  11. NIkon Coolpix A900 Lens Replacement: 11 단계, 이미지 1/2 NIkon Coolpix A900 Lens Replacement: 11 단계, 이미지 2/2
    • Remove the 4.5 mm Phillips #00 screw holding the bracket in the bottom right.
    • Remove the 2.5 mm Phillips #00 rear brace screw.
  12. NIkon Coolpix A900 Lens Replacement: 12 단계, 이미지 1/3 NIkon Coolpix A900 Lens Replacement: 12 단계, 이미지 2/3 NIkon Coolpix A900 Lens Replacement: 12 단계, 이미지 3/3
    • Use your finger to undo the ribbon connector on the top right of the camera.
    • Remove the two 2.5mm Phillips #00 screws holding the small chip in place. Remove the small chip.
    • Remove the final two 4.5 mm Phillips #00 screws from the left side of the brace.
  13. NIkon Coolpix A900 Lens Replacement: 13 단계, 이미지 1/2 NIkon Coolpix A900 Lens Replacement: 13 단계, 이미지 2/2
    • Gently lift the rear brace off of the camera.
  14. NIkon Coolpix A900 Lens Replacement: 14 단계, 이미지 1/2 NIkon Coolpix A900 Lens Replacement: 14 단계, 이미지 2/2
    • Use your finger to undo the three ribbon connectors.
    • Make sure that all ribbons are properly disconnected before proceeding.
  15. NIkon Coolpix A900 Lens Replacement: 15 단계, 이미지 1/3 NIkon Coolpix A900 Lens Replacement: 15 단계, 이미지 2/3 NIkon Coolpix A900 Lens Replacement: 15 단계, 이미지 3/3
    • Carefully lift the lens out of the camera.
    • It may be necessary to gently pry these tabs out of the way to release the lens.
    • When reassembling, make sure that the ribbon cables are flat against the lens to ensure that they don't snag.
  16. NIkon Coolpix A900 Lens Replacement: 16 단계, 이미지 1/1
    • Separate the lens from the body of the camera.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Andres Aronstam
회원 가입일: 09/17/19
735 평판
안내서 5개 작성하였습니다
댓글 2개
How to replace the front-lens of the zoom-lens, when it’s scratched!?!
Tom de Hoop - 답글
Ok I removed the defective one, but my question now is: what model of lens can I replace it with? Is it compatible with any lens from Nikon, or from other manufacturers?
martin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 12
30일 전: 66
전체 시간: 3,623
