주요 콘텐츠로 건너뛰기
NVIDIA SHIELD Portable Motherboard Replacement
필요한 것
  1. NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: 1 단계, 이미지 1/3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: 1 단계, 이미지 2/3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: 1 단계, 이미지 3/3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. NVIDIA SHIELD Portable Motherboard Replacement, Remove Green Grill: 2 단계, 이미지 1/2 NVIDIA SHIELD Portable Motherboard Replacement, Remove Green Grill: 2 단계, 이미지 2/2
    • The green grill is not screwed in so it can be pulled right out.
  3. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: 3 단계, 이미지 1/3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: 3 단계, 이미지 2/3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: 3 단계, 이미지 3/3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Apparatus: 4 단계, 이미지 1/1
    • Pull the battery apparatus out once all cables are removed.
  5. NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: 5 단계, 이미지 1/3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: 5 단계, 이미지 2/3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: 5 단계, 이미지 3/3
    • Cooling is important for electronics, the last thing they want is to overheat.
    • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
    • Lift the fan free after the screws and cable are removed.
  6. NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: 6 단계, 이미지 1/3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: 6 단계, 이미지 2/3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: 6 단계, 이미지 3/3
    • The large board under the back case is the motherboard.
    • Using your T5 Torx screwdriver, remove six screws from the motherboard—two 7.3 mm screws and four 8.4 mm screws.
    • Simply pull gently on the edges of the board, wiggling it if necessary so as not to damage the ports at the top of the board.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Marc Perez
회원 가입일: 09/29/14
545 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-1, Hickman Fall 2014 USF Tampa, Team 1-1, Hickman Fall 2014 회원
USFT-HICKMAN-F14S1G1
4 회원들
안내서 18개 작성하였습니다
댓글 한 개
Hay ich suche Ersatzteile für Nvidia shield Portable ich suche Board da wo kühler drauf ist , weil mein ist kaput gegangen :(
Konstantin Styngu - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 19
전체 시간: 1,838
