주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
NVIDIA SHIELD Portable Motherboard Replacement
필요한 것
  1. NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: 1 단계, 이미지 3개 중 1개 NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: 1 단계, 이미지 3개 중 2개 NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: 1 단계, 이미지 3개 중 3개
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
    댓글 쓰기
  2. NVIDIA SHIELD Portable Motherboard Replacement, Remove Green Grill: 2 단계, 이미지 2개 중 1개 NVIDIA SHIELD Portable Motherboard Replacement, Remove Green Grill: 2 단계, 이미지 2개 중 2개
    • The green grill is not screwed in so it can be pulled right out.
    댓글 쓰기
  3. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: 3 단계, 이미지 3개 중 1개 NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: 3 단계, 이미지 3개 중 2개 NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: 3 단계, 이미지 3개 중 3개
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
    댓글 쓰기
  4. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Apparatus: 4 단계, 이미지 1개 중 1개
    • Pull the battery apparatus out once all cables are removed.
    댓글 쓰기
  5. NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: 5 단계, 이미지 3개 중 1개 NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: 5 단계, 이미지 3개 중 2개 NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: 5 단계, 이미지 3개 중 3개
    • Cooling is important for electronics, the last thing they want is to overheat.
    • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
    • Lift the fan free after the screws and cable are removed.
    댓글 쓰기
  6. NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: 6 단계, 이미지 3개 중 1개 NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: 6 단계, 이미지 3개 중 2개 NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: 6 단계, 이미지 3개 중 3개
    • The large board under the back case is the motherboard.
    • Using your T5 Torx screwdriver, remove six screws from the motherboard—two 7.3 mm screws and four 8.4 mm screws.
    • Simply pull gently on the edges of the board, wiggling it if necessary so as not to damage the ports at the top of the board.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Marc Perez
회원 가입일: 09/29/14
545 평판
안내서 2개를 작성함
USF Tampa, Team 1-1, Hickman Fall 2014 USF Tampa, Team 1-1, Hickman Fall 2014 회원
USFT-HICKMAN-F14S1G1
4 회원들
안내서 18개를 작성함
1가이드 댓글
Hay ich suche Ersatzteile für Nvidia shield Portable ich suche Board da wo kühler drauf ist , weil mein ist kaput gegangen :(
Konstantin Styngu - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 11
지난 30일: 52
전체 시간: 2,505
