주요 콘텐츠로 건너뛰기
NZXT H510i ATX Mid Tower Power Supply Replacement
필요한 것
  1. NZXT H510i ATX Mid Tower Power Supply Replacement, Power Supply: 1 단계, 이미지 2개 중 1개 NZXT H510i ATX Mid Tower Power Supply Replacement, Power Supply: 1 단계, 이미지 2개 중 2개
    • Shut down the computer.
  2. NZXT H510i ATX Mid Tower Power Supply Replacement: 2 단계, 이미지 2개 중 1개 NZXT H510i ATX Mid Tower Power Supply Replacement: 2 단계, 이미지 2개 중 2개
    • Turn off the computer using the switch on the power supply. Unplug the power cable from the power supply.
    • This step is very important. Otherwise the computer will still be powered and it could damage its components or get you an electrical shock.
  3. NZXT H510i ATX Mid Tower Power Supply Replacement: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    • Drain the capacitors by pressing the power switch.
    • Wait several minutes after doing this to ensure that the capacitors are drained of all residual power.
    • Put on the anti-static wrist strap.
    • Caution: This step is crucial in order to avoid personal injury and damage to the computer from electrical discharge.
  4. NZXT H510i ATX Mid Tower Power Supply Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the side panel by unscrewing the captive thumb screws keeping it in place. There will be one towards the top of the panel and another towards the bottom.
  5. NZXT H510i ATX Mid Tower Power Supply Replacement: 5 단계, 이미지 1개 중 1개
    • Identify the old power supply that will be replaced. As shown, it should be towards the bottom of the case, and towards the back of the computer.
    • Take a picture of how the cables are arranged so that this can be replicated later.
  6. NZXT H510i ATX Mid Tower Power Supply Replacement: 6 단계, 이미지 3개 중 1개 NZXT H510i ATX Mid Tower Power Supply Replacement: 6 단계, 이미지 3개 중 2개 NZXT H510i ATX Mid Tower Power Supply Replacement: 6 단계, 이미지 3개 중 3개
    • Unplug the various power cables. These include the Mainbords big 24 pin cable, the processor's power cable, the graphics card power cable, the SATA cables for the fan control, and the motherboard's power cable
  7. NZXT H510i ATX Mid Tower Power Supply Replacement: 7 단계, 이미지 3개 중 1개 NZXT H510i ATX Mid Tower Power Supply Replacement: 7 단계, 이미지 3개 중 2개 NZXT H510i ATX Mid Tower Power Supply Replacement: 7 단계, 이미지 3개 중 3개
    • Using a Phillips #0 screwdriver, remove the four 6-32 x 6mm screws attached to the power supply.
    • Remove the old power supply from the case.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Graeme McCord
회원 가입일: 10/08/20
334 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 53
지난 30일: 153
전체 시간: 5,113
