주요 콘텐츠로 건너뛰기
Nabi 2S Camera Replacement
필요한 것
  1. Nabi 2S Camera Replacement, Nabi 2S Disassembly: 1 단계, 이미지 1/1
    • Remove the red rubber case from the device.
  2. Nabi 2S Camera Replacement: 2 단계, 이미지 1/2 Nabi 2S Camera Replacement: 2 단계, 이미지 2/2
    • Make sure the screen is facing away from you and the back cover is facing you.
    • Using a Phillips #0 Screwdriver, unscrew the 3mm screws counter-clockwise in each corner of the plastic back cover. It will be a total of four screws. The smaller case on the back cover is attached to the main cover so it will not need to be removed.
  3. Nabi 2S Camera Replacement: 3 단계, 이미지 1/1
    • Using the plastic opening tool, remove the case.
    • Removing the case will take a bit of effort and force. We recommend using two hands and if possible another person to help. It will require some gusto.
    • It is helpful to pry at the corners first to loosen the case.
  4. Nabi 2S Camera Replacement: 4 단계, 이미지 1/1
    • After the back case is loosened, remove it from the device to change or access the battery.
  5. Nabi 2S Camera Replacement, Camera: 5 단계, 이미지 1/2 Nabi 2S Camera Replacement, Camera: 5 단계, 이미지 2/2
    • Unscrew the circuit board from the motherboard by using a Phillips #0 screwdriver to unscrew the ten 4mm screws in a counter-clockwise rotation.
  6. Nabi 2S Camera Replacement: 6 단계, 이미지 1/3 Nabi 2S Camera Replacement: 6 단계, 이미지 2/3 Nabi 2S Camera Replacement: 6 단계, 이미지 3/3
    • The camera is attached to the circuit board and then tucked underneath. Gently grip the part attached to the circuit board and pull it up and away from the circuit.
    • Gently slide the camera out from underneath the circuit board.
    • The camera is stuck to the device with adhesive tape so do not rapidly remove it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Molly Scott
회원 가입일: 03/07/16
275 평판
안내서 1개 작성함
Marist, Team 1-4, Laflen Spring 2016 Marist, Team 1-4, Laflen Spring 2016 회원
MARS-LAFLEN-S16S1G4
2 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 181
