주요 콘텐츠로 건너뛰기
Nabi 2S Disassembly
필요한 것
  1. Nabi 2S Disassembly, Nabi 2S Disassembly: 1 단계, 이미지 1개 중 1개
    • Remove the red rubber case from the device.
  2. Nabi 2S Disassembly: 2 단계, 이미지 2개 중 1개 Nabi 2S Disassembly: 2 단계, 이미지 2개 중 2개
    • Make sure the screen is facing away from you and the back cover is facing you.
    • Using a Phillips #0 Screwdriver, unscrew the 3mm screws counter-clockwise in each corner of the plastic back cover. It will be a total of four screws. The smaller case on the back cover is attached to the main cover so it will not need to be removed.
  3. Nabi 2S Disassembly: 3 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, remove the case.
    • Removing the case will take a bit of effort and force. We recommend using two hands and if possible another person to help. It will require some gusto.
    • It is helpful to pry at the corners first to loosen the case.
  4. Nabi 2S Disassembly: 4 단계, 이미지 1개 중 1개
    • After the back case is loosened, remove it from the device to change or access the battery.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Riana Ramirez
회원 가입일: 03/07/16
680 평판
안내서 4개를 작성함
Marist, Team 1-4, Laflen Spring 2016 Marist, Team 1-4, Laflen Spring 2016 회원
MARS-LAFLEN-S16S1G4
2 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 10
전체 시간: 621
