주요 콘텐츠로 건너뛰기
Nabi 2S Screen Replacement
필요한 것
  1. Nabi 2S Screen Replacement, Nabi 2S Disassembly: 1 단계, 이미지 1개 중 1개
    • Remove the red rubber case from the device.
  2. Nabi 2S Screen Replacement: 2 단계, 이미지 2개 중 1개 Nabi 2S Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Make sure the screen is facing away from you and the back cover is facing you.
    • Using a Phillips #0 Screwdriver, unscrew the 3mm screws counter-clockwise in each corner of the plastic back cover. It will be a total of four screws. The smaller case on the back cover is attached to the main cover so it will not need to be removed.
  3. Nabi 2S Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, remove the case.
    • Removing the case will take a bit of effort and force. We recommend using two hands and if possible another person to help. It will require some gusto.
    • It is helpful to pry at the corners first to loosen the case.
  4. Nabi 2S Screen Replacement: 4 단계, 이미지 1개 중 1개
    • After the back case is loosened, remove it from the device to change or access the battery.
  5. Nabi 2S Screen Replacement, Screen: 5 단계, 이미지 2개 중 1개 Nabi 2S Screen Replacement, Screen: 5 단계, 이미지 2개 중 2개
    • Unscrew the circuit board from the motherboard by using a Phillips #0 screwdriver to unscrew the 4mm screws in a counter-clockwise rotation.
  6. Nabi 2S Screen Replacement: 6 단계, 이미지 3개 중 1개 Nabi 2S Screen Replacement: 6 단계, 이미지 3개 중 2개 Nabi 2S Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Pull motherboard away from the plastic.
    • Use hands to detach the screen because it is taped to the back of the motherboard.
    • Grip the screen and slide it out from between the plastic and the circuit board.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Riana Ramirez
회원 가입일: 03/07/16
680 평판
안내서 4개를 작성함
Marist, Team 1-4, Laflen Spring 2016 Marist, Team 1-4, Laflen Spring 2016 회원
MARS-LAFLEN-S16S1G4
2 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 581
