주요 콘텐츠로 건너뛰기
Nabi Big Tab HD24 Power Button Replacement
필요한 것
  1. Nabi Big Tab HD24 Power Button Replacement, Back Assembly: 1 단계, 이미지 1개 중 1개
    • Ensure that the tablet is facing you with the screen on the table.
    • Locate the four red rubber stops at the corners.
  2. Nabi Big Tab HD24 Power Button Replacement: 2 단계, 이미지 1개 중 1개
    • Use your fingers to carefully peel them off the device to reveal the screws underneath.
  3. Nabi Big Tab HD24 Power Button Replacement: 3 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to remove the 9.5 mm screw in each of the four corners.
  4. Nabi Big Tab HD24 Power Button Replacement: 4 단계, 이미지 1개 중 1개
    • Flip the tablet over such that the screen is facing upwards.
    • Locate the the 4 small openings on the sides of the tablet.
    • There should be 2 on the bottom of the tablet, 1 on each side of the tablet viewing it from the front as if you were using it.
    • Do not confuse the openings with the charging port or the USB ports. The openings will be labelled with an icon of a small fan, the Nabi logo.
  5. Nabi Big Tab HD24 Power Button Replacement: 5 단계, 이미지 1개 중 1개
    • Insert a metal spudger into one of the openings and carefully pop the device open by applying a steady downward force.
    • Repeat for the other three openings.
  6. Nabi Big Tab HD24 Power Button Replacement: 6 단계, 이미지 2개 중 1개 Nabi Big Tab HD24 Power Button Replacement: 6 단계, 이미지 2개 중 2개
    • Flip the device over so that the back assembly is facing you.
    • Use a plastic opening tool to carefully pry open the device from its hinges.
    • Take care when opening the device as there are cables running internally that are connected to both the front and the back assemblies.
  7. Nabi Big Tab HD24 Power Button Replacement: 7 단계, 이미지 2개 중 1개 Nabi Big Tab HD24 Power Button Replacement: 7 단계, 이미지 2개 중 2개
    • Locate the white port that connects the back panel to the circuit board on the back of the display.
    • Carefully pull the plastic connector straight out.
  8. Nabi Big Tab HD24 Power Button Replacement: 8 단계, 이미지 1개 중 1개
    • Be careful of the aluminum foil tape, as it can easily rip.
    • Carefully lift up the aluminum foil tape with your fingers so that the ribbon connector reveals itself.
    • Do not try to pull the ribbon cables off the screen as there is a plastic piece surrounding the ribbon cables glued onto the metal display.
  9. Nabi Big Tab HD24 Power Button Replacement: 9 단계, 이미지 1개 중 1개
    • Firmly press the two switches located on the sides of the connector and disconnect the connector from its connections.
    • Leave the connector disconnected but still intact with the metal display.
  10. Nabi Big Tab HD24 Power Button Replacement: 10 단계, 이미지 1개 중 1개
    • Use a plastic opening tool and carefully push it underneath the grey plastic case surrounding the ribbon cable.
    • Apply a downward force to carefully peel the grey plastic off of the metal display.
  11. Nabi Big Tab HD24 Power Button Replacement: 11 단계, 이미지 1개 중 1개
    • Locate the two cables running on both sides of the device found at the bottom side of the screen.
  12. Nabi Big Tab HD24 Power Button Replacement: 12 단계, 이미지 2개 중 1개 Nabi Big Tab HD24 Power Button Replacement: 12 단계, 이미지 2개 중 2개
    • Carefully grab both sides of the white plastic piece with your fingers and gently pull directly upward.
    • Do not pull from the red and black cable as it is not very sturdy and may come undone from the connector.
  13. Nabi Big Tab HD24 Power Button Replacement, Power Button: 13 단계, 이미지 2개 중 1개 Nabi Big Tab HD24 Power Button Replacement, Power Button: 13 단계, 이미지 2개 중 2개
    • Locate the power button assembly on the side with all the circuit boards.
    • The power button will be on the side closest to the screen when the device is opened up.
  14. Nabi Big Tab HD24 Power Button Replacement: 14 단계, 이미지 1개 중 1개
    • Lift up the black plastic tab holding the white fiber cable with the blue tip.
  15. Nabi Big Tab HD24 Power Button Replacement: 15 단계, 이미지 1개 중 1개
    • Remove the fiber cable with a blue tip by gently sliding it out.
  16. Nabi Big Tab HD24 Power Button Replacement: 16 단계, 이미지 2개 중 1개 Nabi Big Tab HD24 Power Button Replacement: 16 단계, 이미지 2개 중 2개
    • Remove the 2 silver 4.5 mm screws holding the power button assembly in place using the Phillips #1 screwdriver.
    • Take out the circuit board and replace it with your new one.
    • Be sure not to remove the black padding along the edge of the tablet.
결론
작성자
4다른 기여자 명과 함께
Nathan Lubega
회원 가입일: 10/05/16
107 평판
안내서 1개를 작성함
Cal Poly, Team 4-1, Livingston Fall 2016 Cal Poly, Team 4-1, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S4G1
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 580
