주요 콘텐츠로 건너뛰기
Nabi Jr Battery Replacement
필요한 것
  1. Nabi Jr Battery Replacement, Rear Case: 1 단계, 이미지 1/1
    • Remove the red rubber case from the device. This should come off with ease.
  2. Nabi Jr Battery Replacement: 2 단계, 이미지 1/1
    • Turn the device so the screen is facing away from you.
    • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
  3. Nabi Jr Battery Replacement: 3 단계, 이미지 1/1
    • Remove the device casing using a small plastic pry bar.
    • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
  4. Nabi Jr Battery Replacement: 4 단계, 이미지 1/1
    • After loosening the back cover, remove it from the device so you can get at the innards.
  5. Nabi Jr Battery Replacement, Battery: 5 단계, 이미지 1/1
    • Lift the battery up from the motherboard.
    • Don't rip the soldered wires from the board.
    • The battery is stuck to the motherboard with adhesive, it may take a little pull to separate.
  6. Nabi Jr Battery Replacement: 6 단계, 이미지 1/1
    • Remove the battery from the motherboard
    • De-solder the colored wires
    • Be sure to note the order in which the wires are connected to the board before desoldering them.
    • Be careful while removing the solder off of the colored battery wires. The soldering iron will be extremely hot
  7. Nabi Jr Battery Replacement: 7 단계, 이미지 1/2 Nabi Jr Battery Replacement: 7 단계, 이미지 2/2
    • Replace the old battery with the new one
    • Solder the wires of the new battery into the pads on the motherboard
    • Be careful when soldering the wires in. Soldering iron will be extremely hot
  8. Nabi Jr Battery Replacement: 8 단계, 이미지 1/1
    • Once the wires are fully soldered, put the new battery back to the initial position
    • Close the case by putting the back cover back on the device
    • Will take some force
    • Make sure the battery is not in the way of the back cover
  9. Nabi Jr Battery Replacement: 9 단계, 이미지 1/1
    • Once the back cover is on, screw in the four screws that you had taken off in the beginning
    • Put the red rubber casing back on.
결론
If all the steps were followed correctly, the device should be fully closed and ready to go
다른 4명이 해당 안내서를 완성하였습니다.
Jimmy Nguyen
회원 가입일: 03/24/15
271 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 회원
UMASSD-VIJAYBHASKAR-S15S4G3
3 회원들
안내서 12개 작성하였습니다
댓글 7개
Thank you for sharing the idea ,but I need that NABI JR battery. So ,where from I can purchase it .
Lus Ka - 답글
I have seen them on ebay but it's easier to find a Nabi 2 battery on ebay. The Nabi 2 battery is quite a bit larger but with a very minor mod to the Nabi Jr. the Nabi 2 battery will fit and give you a much longer run time from a single charge.
darcshadow -
My old Nabi jr battery is a plug in with 2 reds 1 white and 2 black wires. My new Cameron sino battery is blue green red yellow black. What is the order to resolder them.
Dennis Blixt - 답글
I have the same problem with the problem of the replacement battery not having the same wiring configuration or plug. Did you ever get this resolved?
Delores Duke -
Where can I buy the battery live in Mexico
Roos - 답글
My old Nabi jr battery is a plug in with 2 reds 1 white and 2 black wires. My new Cameron sino battery is blue green red yellow black. What is the order to resolder them. I can’t find anywhere to purchase the non solder style battery. Please help
Delores Duke - 답글
Caution!!! Check your battery type by using these instructions to open your Nabi Jr FIRST. This works with the older style battery only. Some models have a newer 6 wire McNair battery that just unplugs. Unfortunately, I haven't been able to locate a replacement for that just yet.
John M. - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 11,691
