주요 콘텐츠로 건너뛰기
Nabi Jr Rear Case Replacement
필요한 것
  1. Nabi Jr Rear Case Replacement, Rear Case: 1 단계, 이미지 1/1
    • Remove the red rubber case from the device. This should come off with ease.
  2. Nabi Jr Rear Case Replacement: 2 단계, 이미지 1/1
    • Turn the device so the screen is facing away from you.
    • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
  3. Nabi Jr Rear Case Replacement: 3 단계, 이미지 1/1
    • Remove the device casing using a small plastic pry bar.
    • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
  4. Nabi Jr Rear Case Replacement: 4 단계, 이미지 1/1
    • After loosening the back cover, remove it from the device so you can get at the innards.
결론
Tobias Young
회원 가입일: 03/24/15
27 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 회원
UMASSD-VIJAYBHASKAR-S15S4G3
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 9
전체 시간: 409
