주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
  1. Remove the red rubber case from the device. This should come off with ease.
    • Remove the red rubber case from the device. This should come off with ease.
  2. Turn the device so the screen is facing away from you.
    • Turn the device so the screen is facing away from you.
    • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
  3. Remove the device casing using a small plastic pry bar.
    • Remove the device casing using a small plastic pry bar.
    • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
  4. After loosening the back cover, remove it from the device so you can get at the innards.
    • After loosening the back cover, remove it from the device so you can get at the innards.
  5. The speakers are located near the top of the device close to the camera.
    • The speakers are located near the top of the device close to the camera.
    • Using a desoldering tool, remove the speakers from the pads they are soldered to.
    • Note that the red wire is removed from the pad labeled with a "+" and the black wire comes from the pad labeled with a "-".
    • Solder the new speaker's wires onto their respective pads
결론
Tobias Young
회원 가입일: 2015년 03월 24일
27 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 회원
UMASSD-VIJAYBHASKAR-S15S4G3
3 회원들
안내서 12개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 772
