주요 콘텐츠로 건너뛰기
Nail Clipper Reassembly
  1. Nail Clipper Reassembly, Nail Clipper Reassembly: 1 단계, 이미지 3개 중 1개 Nail Clipper Reassembly, Nail Clipper Reassembly: 1 단계, 이미지 3개 중 2개 Nail Clipper Reassembly, Nail Clipper Reassembly: 1 단계, 이미지 3개 중 3개
    • Insert the rod through the bottom hole of the clipper body, and continue through the top hole.
    • The side of the rod with the notch should be inserted first.
    • Note: The top of the clipper body will often have a pick/file attached to it. If no pick/file is present, either side can serve as the top or the bottom.
  2. Nail Clipper Reassembly: 2 단계, 이미지 1개 중 1개
    • Compress the body of the clippers to reveal the notch.
  3. Nail Clipper Reassembly: 3 단계, 이미지 1개 중 1개
    • Rotate the rod until the notch opening faces away from the body.
    • This allows for easier completion of the following step.
  4. Nail Clipper Reassembly: 4 단계, 이미지 3개 중 1개 Nail Clipper Reassembly: 4 단계, 이미지 3개 중 2개 Nail Clipper Reassembly: 4 단계, 이미지 3개 중 3개
    • Place the hole of the lever into the revealed rod notch.
    • Release the compressed nail clipper body to lock the lever into place.
    • Note: Position of the lever does not matter at this point.
  5. Nail Clipper Reassembly: 5 단계, 이미지 3개 중 1개 Nail Clipper Reassembly: 5 단계, 이미지 3개 중 2개 Nail Clipper Reassembly: 5 단계, 이미지 3개 중 3개
    • Swivel the lever into its normal position, and test the nail clippers' functionality.
결론
If you follow these steps, your nail clippers should be back to working order.
다른 89명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Robert Weber
회원 가입일: 04/09/15
2,149 평판
안내서 1개를 작성함
Cal Poly, Team 30-5, Green Spring 2015 Cal Poly, Team 30-5, Green Spring 2015 회원
CPSU-GREEN-S15S30G5
5 회원들
안내서 32개를 작성함
32가이드 댓글
Thank you so much ! My fingers are arthritic and I was frustrated until I found your instructions.
marvin - 답글
Thank you. Knew it was simple! Love this website.
jonathanl.aguiar - 답글
This is the dumbest “repair guide” I have ever seen. It is not a repair, because they are not broken, it’s a re-assembly.
Albert E - 답글
That's why it says reassembly 🤨
Blake Jordan-Borns -
Thank you so much!!!! I could only find one pair in my house and was feeling desperate. This is the best guide to repair and I’m glad you posted under broken nail clippers because that’s what I considered mine to be and how I looked it up.
Tanya Bishop - 답글
댓글 쓰기
조회 통계:
지난 24시간: 40
지난 7일: 322
지난 30일: 1,373
전체 시간: 145,972
