주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. NeXTstation 수리는 저희 서비스 설명서를 사용하십시오.
  1. NeXTstation Teardown, NeXTstation Teardown: 1 단계, 이미지 1/3 NeXTstation Teardown, NeXTstation Teardown: 1 단계, 이미지 2/3 NeXTstation Teardown, NeXTstation Teardown: 1 단계, 이미지 3/3
    • The NeXTStation, this is a great addition to any computer collection.
  2. NeXTstation Teardown: 2 단계, 이미지 1/3 NeXTstation Teardown: 2 단계, 이미지 2/3 NeXTstation Teardown: 2 단계, 이미지 3/3
    • Turn the NeXTStation around, and remove this screw:
    • Then, lift the top cover of the computer. This will reveal the guts.
    • The ports from left to right: SCSI2, Keyboard & Mouse, DSP Port, DB-19(MegaPixel Display), DB-9(Serial), RJ-45(Ethernet), Coaxial (10b2 Ethernet), Power
    • I find notes in everything!
  3. NeXTstation Teardown: 3 단계, 이미지 1/2 NeXTstation Teardown: 3 단계, 이미지 2/2
    • Removing the hard drive:
    • The NeXTStation uses a 50-Pin SCSI Hard Drive up to 4GB.
    • Remove all of the cables from the logic board.
  4. NeXTstation Teardown: 4 단계, 이미지 1/3 NeXTstation Teardown: 4 단계, 이미지 2/3 NeXTstation Teardown: 4 단계, 이미지 3/3
    • Then remove this screw.
    • Once the screw is removed, pivot the drive up on a 45 Degree angle, then slide it out.
  5. NeXTstation Teardown: 5 단계, 이미지 1/1
    • The Hard Drive & Caddy
  6. NeXTstation Teardown: 6 단계, 이미지 1/3 NeXTstation Teardown: 6 단계, 이미지 2/3 NeXTstation Teardown: 6 단계, 이미지 3/3
    • Removing the floppy disk drive:
    • The NeXTStation uses a non-standard 2.88MB 3.5" floppy drive, though it uses the standard floppy connector.
    • Remove the floppy cable.
    • Then, remove this screw.
  7. NeXTstation Teardown: 7 단계, 이미지 1/3 NeXTstation Teardown: 7 단계, 이미지 2/3 NeXTstation Teardown: 7 단계, 이미지 3/3
    • Then, just like the hard drive, pivot the drive up 45 degrees, and pull it out.
  8. NeXTstation Teardown: 8 단계, 이미지 1/3 NeXTstation Teardown: 8 단계, 이미지 2/3 NeXTstation Teardown: 8 단계, 이미지 3/3
    • Removing the fan:
    • Remove this connector.
    • Remove these screws.
    • Remove the fan.
  9. NeXTstation Teardown: 9 단계, 이미지 1/3 NeXTstation Teardown: 9 단계, 이미지 2/3 NeXTstation Teardown: 9 단계, 이미지 3/3
    • Removing the logic board:
    • Remove the power supply connector. Just lift it straight up, and it should come free.
    • Remove this screw.
  10. NeXTstation Teardown: 10 단계, 이미지 1/3 NeXTstation Teardown: 10 단계, 이미지 2/3 NeXTstation Teardown: 10 단계, 이미지 3/3
    • Lift the end of the logic board(away from the ports), and slide it away from the ports.
    • Now, set the board aside.
  11. NeXTstation Teardown: 11 단계, 이미지 1/3 NeXTstation Teardown: 11 단계, 이미지 2/3 NeXTstation Teardown: 11 단계, 이미지 3/3
    • Power Supply:
    • Lift the power supply up, and out.
  12. NeXTstation Teardown: 12 단계, 이미지 1/1
    • The Logic Board Overview:
    • The Board has a 25Mhz Motorola 68040 CPU, This board features a ton of chips for something made nearly 20 years ago.
    • The CPU: Motorola XC68040RC25
    • The Co-Procesor: MB610313
    • Motorola Chips
    • Intel Chips
    • AMD Chips (Intel and AMD In the same computer?)
    • Fujitsu Chips
  13. NeXTstation Teardown: 13 단계, 이미지 1/3 NeXTstation Teardown: 13 단계, 이미지 2/3 NeXTstation Teardown: 13 단계, 이미지 3/3
    • Made in the USA, you don't see this anymore.
    • The Serial #
    • Looks like my NeXTStation came from WilTel.
    • It is model # N1100
Chris Green
회원 가입일: 10/11/09
36,990 평판
안내서 49개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,535개 작성하였습니다
댓글 3개
http://www.youtube.com/watch?v=jhfUKEu7s...
The Machine to Build the Machines:
Watch NeXT's revolutionary computer controlled (NeXT Cubes - no less) assembly line in action!
Juddy - 답글
Juddy로 부터 인용:
http://www.youtube.com/watch?v=jhfUKEu7s... The Machine to Build the Machines: Watch NeXT's revolutionary computer controlled (NeXT Cubes - no less) assembly line in action!
Amazing!
Chris Green - 답글
MB610313 - ICP (Integrated Channel Processor). Basically DMA on steroids for almost all of the main sub components of the system. I believe that the cube, or at least the 25Mhz 030/040 cubes, had two of these.
HotelCoralEssex - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 23
30일 전: 74
전체 시간: 30,838
