주요 콘텐츠로 건너뛰기
Neato BOTVAC CONNECTED Filter Replacement
필요한 것
  1. Neato BOTVAC CONNECTED Filter Replacement, Battery: 1 단계, 이미지 1/1
    • Place the top of the Neato Botvac Connected against a flat surface.
  2. Neato BOTVAC CONNECTED Filter Replacement: 2 단계, 이미지 1/2 Neato BOTVAC CONNECTED Filter Replacement: 2 단계, 이미지 2/2
    • Remove the two 5.5 mm screws with a Phillips #2 screwdriver.
  3. Neato BOTVAC CONNECTED Filter Replacement: 3 단계, 이미지 1/2 Neato BOTVAC CONNECTED Filter Replacement: 3 단계, 이미지 2/2
    • Using the spudger, remove the panel covering the battery.
  4. Neato BOTVAC CONNECTED Filter Replacement: 4 단계, 이미지 1/3 Neato BOTVAC CONNECTED Filter Replacement: 4 단계, 이미지 2/3 Neato BOTVAC CONNECTED Filter Replacement: 4 단계, 이미지 3/3
    • Gently remove the connecting wires attached to the battery.
    • The wires are attached to the vacuum through a clip.
  5. Neato BOTVAC CONNECTED Filter Replacement: 5 단계, 이미지 1/1
    • Using the spudger, gently remove the battery from the device.
  6. Neato BOTVAC CONNECTED Filter Replacement, Filter: 6 단계, 이미지 1/1
    • Flip the cleaner around and locate the front panel.
  7. Neato BOTVAC CONNECTED Filter Replacement: 7 단계, 이미지 1/1
    • Gently remove the front panel by opening it with a spudger.
  8. Neato BOTVAC CONNECTED Filter Replacement: 8 단계, 이미지 1/2 Neato BOTVAC CONNECTED Filter Replacement: 8 단계, 이미지 2/2
    • Use the spudger to gently remove the paper filter.
결론
Justin Silva
회원 가입일: 03/20/23
645 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 6-3, Botvin Spring 2023 UMass Dartmouth, Team 6-3, Botvin Spring 2023 회원
UMASSD-BOTVIN-S23S6G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 75
