주요 콘텐츠로 건너뛰기
Neato BOTVAC D5 Li-ion Battery Replacement
필요한 것
  1. Neato BOTVAC D5 Li-ion Battery Replacement, Li-ion Battery: 1 단계, 이미지 1/2 Neato BOTVAC D5 Li-ion Battery Replacement, Li-ion Battery: 1 단계, 이미지 2/2
    • Turn the Neato Botvac upside down so the brushes and wheels are facing upward.
    • Unscrew the two 24 mm captive screws holding the battery compartment shut.
    • They will not come out of the cover, since the battery is the most replaced part. They are located right under the main brush.
  2. Neato BOTVAC D5 Li-ion Battery Replacement: 2 단계, 이미지 1/2 Neato BOTVAC D5 Li-ion Battery Replacement: 2 단계, 이미지 2/2
    • Carefully pull the battery out of it's socket so you can clearly see the wires connecting it to the robot.
    • Carefully unplug the connection, freeing the battery.
결론
Elijah Baker
회원 가입일: 10/30/23
220 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 3-3, Konn Fall 2023 UMass Dartmouth, Team 3-3, Konn Fall 2023 회원
UMASSD-KONN-F23S3G3
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
What is each function of the wires that come out of the D5 14.4V 6.5a h 93.6 Wh battery?
Red-_________
White-_________
Black-_________
Black-_________
Blue-_________
Yellow-_________
sells-glisten0k@icloud.com - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 25
전체 시간: 205
