주요 콘텐츠로 건너뛰기
Neato BOTVAC D5 Main Brush Motor Replacement
필요한 것
  1. Neato BOTVAC D5 Main Brush Motor Replacement, Side Brush: 1 단계, 이미지 1/1
    • Turn the Neato Botvac upside down so the brushes and wheels are facing upward.
  2. Neato BOTVAC D5 Main Brush Motor Replacement: 2 단계, 이미지 1/2 Neato BOTVAC D5 Main Brush Motor Replacement: 2 단계, 이미지 2/2
    • Firmly grasp and pull on the side brush and it will pop right off
  3. Neato BOTVAC D5 Main Brush Motor Replacement, Main Roller Brush: 3 단계, 이미지 1/2 Neato BOTVAC D5 Main Brush Motor Replacement, Main Roller Brush: 3 단계, 이미지 2/2
    • Pop the tabs shown on the main brush cover, and then pull. It should come right off. You can put it aside for now.
  4. Neato BOTVAC D5 Main Brush Motor Replacement: 4 단계, 이미지 1/2 Neato BOTVAC D5 Main Brush Motor Replacement: 4 단계, 이미지 2/2
    • The Main brush will pop right out when you attempt to remove it.
    • When replacing the main brush make sure to orient it correctly.
  5. Neato BOTVAC D5 Main Brush Motor Replacement, Main Brush Motor: 5 단계, 이미지 1/2 Neato BOTVAC D5 Main Brush Motor Replacement, Main Brush Motor: 5 단계, 이미지 2/2
    • Pull down the latch under the sensor and then carefully remove it from the unit.
  6. Neato BOTVAC D5 Main Brush Motor Replacement: 6 단계, 이미지 1/2 Neato BOTVAC D5 Main Brush Motor Replacement: 6 단계, 이미지 2/2
    • Flip the unit over and locate the gap next to the motor, on the same side the sensor was removed from. Insert your flathead screwdriver and twist lightly to pop off the motor.
  7. Neato BOTVAC D5 Main Brush Motor Replacement: 7 단계, 이미지 1/1
    • Disconnect the wiring connecting the motor to the circuit board and remove the brush motor.
결론
Laurent Kwan
회원 가입일: 10/30/23
337 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 3-3, Konn Fall 2023 UMass Dartmouth, Team 3-3, Konn Fall 2023 회원
UMASSD-KONN-F23S3G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 24
전체 시간: 168
