주요 콘텐츠로 건너뛰기
Neato Botvac 80 Top Face Panel Replacement
필요한 것
  1. Neato Botvac 80 Top Face Panel Replacement, Rear Bumper: 1 단계, 이미지 1/1
    • Grab the rear bumper with both hands on either side.
  2. Neato Botvac 80 Top Face Panel Replacement: 2 단계, 이미지 1/1
    • Pull the left and right sides away from the machine to unclip the bumper. This requires that you bend the plastic a little bit. Unclip one side a little bit and allow the prong to rest on the side of the machine. Then unclip the other side and pull off the bumper parallel to both sides
  3. Neato Botvac 80 Top Face Panel Replacement, Top Face Panel: 3 단계, 이미지 1/2 Neato Botvac 80 Top Face Panel Replacement, Top Face Panel: 3 단계, 이미지 2/2
    • Looking from above, remove the two 11mm screws with a torx T10 screwdriver.
  4. Neato Botvac 80 Top Face Panel Replacement: 4 단계, 이미지 1/1
    • Begin by placing the robot on it's back and removing the six 11m screws using a Torx T10 screwdriver.
  5. Neato Botvac 80 Top Face Panel Replacement: 5 단계, 이미지 1/3 Neato Botvac 80 Top Face Panel Replacement: 5 단계, 이미지 2/3 Neato Botvac 80 Top Face Panel Replacement: 5 단계, 이미지 3/3
    • To remove the top, you must press in both of the clamps at the same time and push upwards.
    • When removing the top, before you can completely take it off you must unplug the LCD power cable from the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Brandon Blank
회원 가입일: 02/02/17
675 평판
안내서 5개 작성하였습니다
USF Tampa, Team 17-5, Blackwell Spring 2017 USF Tampa, Team 17-5, Blackwell Spring 2017 회원
USFT-BLACKWELL-S17S17G5
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 882
